Hello.
I just bought a Dell PowerEdge R720 with the following specs:
2 x CPU E5-2650 v2
192 GB RAM, 2 Perc RAID controllers (2 SATA )
1 NVidia Grid K1 vGPU Card
I followed this procedure:
-Insert Dell Open Management disc and perform Windows 2012 Datacenter R2 x64 with Dell built-in drivers.
-Run Dell Bios Update for R720 (v2.2.3) latest version.
-Run Chipset Update and recommended drivers from support.dell.com (according to my Service Tag)
-Apply Windows Updates and reboot.
The system is OK until now, but the problems begin in the next step:
-after reboot, install NVidia Grid vGPU driver 332.83 (http://www.nvidia.com/download/driverResults.aspx/74598/en-us)
after installing this video driver, I reboot the system and when Windows logo appears and waiting dots starts spinning the screen goes black for a couple of seconds and then I receive a blue screen:
Page_Fault_In_NonPaged_Area (Nvlddmkm.sys)
Then the system collects some data and enters an infinite loop of reboots.
If I start the server in Safe Mode and remove the driver everything just works fine again.
I also tried with driver 333.11 for Grid K1 and receive the same error.
Does anyone know if this is a known issue or if there is any newer or stable driver for this card?
According to NVidia support, this card is supported on Windows 2012 R2.
I also tried the TDR registry key values for detection delay but no success! (http://www.instructables.com/id/How-to-Fix-the-Nvlddmkm-Error/)
Any help will be appreciated!
Thanks in advance.
