Hi, I used the custom carrier board, the usb can not been found in kernel, can been found in u-boot, How can I load kernel with out Configuring the GUI.
Before flashing the board, you can run l4t_create_default_user.sh script under Linux_for_Tegra/tools.
Added note: You should also get a serial console boot log. USB does not require a logged in user to work, and serial console can see boot messages even without a logged in user (obviously having the user pre-created helps since logging in is needed to try a number of possibilities, but if the USB keyboard doesn’t work, then login won’t much matter). Serial console also makes it easy to get a complete boot log.
