I’m trying to install sdkmanager.
The situation is as below.
Install Ubuntu 18.04 in my PC.
NVIDIA SDK Manager download
sudo apt install ./sdkmanager_1.1.0-6343_amd64.deb
sdkmanager → error
sudo apt-get update
sudo apt-get upgrade
sudo apt install libnss3-dev
sudo apt install libgtk-3-0
sudo apt install libxss1
sdkmanager → error
sdkmanager --user hiro.ohnishi@ai-e.co.jp → now
current error message is,
Gtk-WARNING **: 01:41:28.496: cannot open display: :0
How can I use sdkmanager?
What was the error here (a specific log message would help)? Also, downloads from SDKM depend on a manifest file, which is itself downloaded. Do you have internet access on your PC? Is there any kind of firewall or proxy involved?
I found the error as below.
Reading package lists… Done
Building dependency tree
Reading state information… Done
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
google-chrome-stable : Depends: libappindicator3-1 but it is not installed
Recommends: libu2f-udev but it is not installed
Recommends: libvulkan1 but it is not installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
Run this on the host PC, then try again:
sudo apt update
sudo apt --fix-broken install
Do you still see the error? Did the sudo apt --fix-broken install appear to make any changes?
Thank you
I could solve the problem about install.
But I found this error, couldn’t solve.
“(sdkmanager:18141): Gtk-WARNING **: 10:12:24.561: cannot open display:”
The regular JetPack/SDK Manager requires a GUI. Were you operating from command line?
Note that you can flash from command line without the GUI. Someone may need to verify this example since I do not have an NX, but if the device shows up on the host PC with “lsusb -d 0955:”, then in the “Linux_for_Tegra/” directory command line flash would go something like this:
sudo ./flash.sh jetson-nx mmcblk0p1
To use JetPack/SDKM directly be sure you are running in a GUI environment. If you still get that error while in a GUI environment, then more debugging would be needed.
Oh, I see.
I will flash without GUI.
Thank you very much.
I had the same problem. Need to set X Display manually:
$export DISPLAY=:0
$ sdkmanager
→ show the GUI
