Hi teachers,
Orin’s SDIO interface is connected to an eMMC,when we tested the signal, we found that the signal amplitude of D0~D3 is greater than 1.8V, which is about 2.2V, what is the reason?
See below for a schematic. Thanks.
Hi, only SD CARD or SDIO is supported as you can see in Design Gudie.
Yea, I only connected a emmc ,and my sdio voltage is 1.8V, but the measured voltage is about 2.2V as you seen in the third figure. And I want to know what caused ?
Please add “only-1-8-v” to your device tree node.
Basically, just copy the sdmmc4 node as that one is on board emmc.
Hi Wayne,
My eMMC configuration is shown below,please check it for me,thank you.
sdmmc1: sdhci@3400000 {
compatible = “nvidia,tegra234-sdhci”, “nvidia,tegra194-sdhci”;
reg = <0x0 0x3400000 0x0 0x00020000>;
interrupts = < 0 TEGRA234_IRQ_SDMMC1 0x04>;
#if TEGRA_IOMMU_DT_VERSION >= DT_VERSION_2
interconnects = <&mc TEGRA234_MEMORY_CLIENT_SDMMCRA>,
<&mc TEGRA234_MEMORY_CLIENT_SDMMCWA>;
interconnect-names = “dma-mem”, “dma-mem”;
#endif
iommus = <&smmu_niso1 TEGRA_SID_NISO1_SDMMC1A>;
dma-coherent;
max-clk-limit = <200000000>;
ddr-clk-limit = <51000000>;
bus-width = <4>;
only-1-8-v;
ignore-pm-notify;
keep-power-in-suspend;
non-removable;
cap-mmc-highspeed;
cap-sd-highspeed;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
#if TEGRA_SDMMC_VERSION >= DT_VERSION_2
nvidia,pad-autocal-pull-up-offset-1v8-timeout = <0x0a>;
nvidia,pad-autocal-pull-down-offset-1v8-timeout =
<0x0a>;
nvidia,pad-autocal-pull-up-offset-3v3-timeout = <0x0a>;
nvidia,pad-autocal-pull-down-offset-3v3-timeout =
<0x0a>;
nvidia,default-tap = <18>;
nvidia,default-trim = <0x7>;
nvidia,dqs-trim = <40>;
assigned-clocks = <&bpmp TEGRA234_CLK_SDMMC1>;
assigned-clock-parents =
<&bpmp TEGRA234_CLK_PLLC4_MUXED>;
#endif
resets = <&bpmp_resets TEGRA234_RESET_SDMMC1>;
reset-names = “sdhci”;
pll_source = “pll_p”, “pll_c4_muxed”;
nvidia,set-parent-clk;
nvidia,parent_clk_list = “pll_p”, “pll_p”, “pll_p”, “pll_p”, “pll_p”, “pll_c4_muxed”, “pll_c4_muxed”, “pll_c4_muxed”, “pll_c4_muxed”, “pll_c4_muxed”, “NULL”;
clocks = <&bpmp_clks TEGRA234_CLK_SDMMC1>,
<&bpmp_clks TEGRA234_CLK_PLLP_OUT0>,
<&bpmp_clks TEGRA234_CLK_PLLC4_MUXED>,
<&bpmp_clks TEGRA234_CLK_SDMMC_LEGACY_TM>,
<&bpmp_clks TEGRA234_CLK_SDMMC_LEGACY_TM>;
clock-names = “sdmmc”, “pll_p”, “pll_c4_muxed”, “sdmmc_legacy_tm”, “tmclk”;
status = “disabled”;
Sorry for the late response, is this still an issue to support? Thanks
