I am using a virtual machine on Windows 11. The virtual machine is Ubuntu-22.04.3 as I saw that was compatible
I put the device into recovery mode by using the command:
sudo reboot --force forced-recovery
I could not get it working via the buttons after many attempts
I am connected to the Jetson from my desktop via a USB-C cable from the front port (and powering the Jetson with the USB-C power adapter into the port above the DC jack). I hear the connect sound when plugging it into the desktop
So dual boot is recommended instead so then it is only 1 OS at a time to not get the USB connections mixed up? Is this the same when connecting via Ethernet? I was using a VM just to hopefully save some time so I could switch between Windows and Linux.
Now I can detect the Orin and am using the 64GB developer model when dual booting on Linux. It fails installation though and here’s the screenshot. I tried twice and still the same thing.
Is there a way to confirm the autosuspend has been disabled? I see it looks to still be a USB timeout error from the cmd line. My desktop and USB cable are all stable and brand new btw
