Hi…
According to PCN212822 announced in 2025, Samsung DRAM will be added to Orin NX 8G modules produced starting December 15, 2025.
Is there a way to check whether Samsung DRAM or Micron DRAM is assembled in the Orin NX 8G module released after December 15, 2025?
I want to know how to identify the module’s components using part numbers, etc., before visually inspecting them.
Thanks,
Raymond Lee
kayccc
3
Customers may receive mixed shipments, may I know why need to identify them to do the visually inspecting?
this might help:
sudo python3 jetson_orin_nx_8gb_memory_vendor.py
jetson_orin_nx_8gb_memory_vendor.py.txt (6.3 KB)
or
sudo cat /sys/kernel/debug/bpmp/debug/emc/dram_info
Manufacturer ID (MR5): 1
Revision ID-1 (MR6): ...
Revision ID-2 (MR7): ...
IO Width/Density/Type (MR8): ...
then it has Samsung DRAM. If MR5 is 255, it has Micron.
