About Relationship between CUDA, Nvdec, and Nvjpg
Are CUDA, Nvdec, and Nvjpg hardware decoders related?
Thank you.
These are independent hardware blocks. Are not related. For hardware architecture, please check
https://developer.nvidia.com/embedded/downloads#?search=trm
Tegra X1 SoC Technical Reference Manual
I know the hardware decoder uses hardware acceleration
Doesn’t the hardware decoder use cuda internally?
cuda can only be used when coded using cuda syntax, right?
Thank you.
This is a tegra x1 processor block diagram. Can I check cuda here?
Thank you.
NVDEC is independent hardware decoder and do not use GPU. CUDA is the interface of using GPU engine. A compiled/run CUDA application is executed on Maxwell GPU.
