I used my PC to connect it. However, the WIFI disconnected frequently… In the Jeston Xavier NX I connected to 1 LiDAR, two cameras and two GNSS modules. Do you think is it the performance of the Jetson (I mean too many processing threds make the WIFI to be disconnected)?
Should I update the Network Manager? Do you think it will help?
Have you ever see a mode switch in your system? like from AP to station mode and back, or there is some errors there. This could be record in the kernel message.
Need to figure out if this is something related to wifi firmware or the system.
