Ada 5000 for Parabricks
I am planning to buy a workstation for my research lab with the intention of running parabricks. The Parabricks Docs list a handful of GPUs, but I was unsure if this is a closed list of options. Due to some limitations with ordering, it is difficult to obtain these GPUs for our machine. Alternatively we were considering using 2 Ada 5000 GPUs in the machine. Will they be able to run Parabricks assuming all other system requirements are met by the machine?
Thank you in advance for your help
Hi @zane.hamdan,
Yes, in the hardware requirements in the docs, we list which GPUs we have internally tested Parabricks on, however the list is not exhaustive. As long as it meets the system requirements, the software will still run.
