Affects of unexpected power outage in jetson nano
Is there any chance that jetson nano will not boot correctly or system files will get corrupted, in case of sudden power outage or just power is disconnected accidentally from jetson nano?
Although, I have seen that while jetson nano is running and just unplug the power adapter did not do any harm and booted normally, I just wanted an expert opinion from forum.
Regardless of Jetson nano - a power outage during a write operation may render most file systems corrupted or in case of sd-card even make it unusable.
When you have seen situations where a power disconnect did not any harm you simply have been lucky that in this moment there was no write operation…
