The sdk version is Tegra_Linux_Sample-Root-Filesystem_R35.3.1_aarch64.tbz2
Some questions to confirm,
- Is your device using a dev kit or a custom carrier board?
- What flashing method you use? Please provide flashing command or referred link.
The custom carrier board used. See the figure below for the flashing command
The hardware is good. Modify the content in the figure below and re-burn it, the system will not start. Restore the modification, the system will not start either
Please build the UEFI from GitHub - NVIDIA/edk2-nvidia: NVIDIA EDK2 platform support with tag r35.3.1
And replace Linux_for_Tegra/bootloader/uefi_jetson.bin
with uefi_Jetson_DEBUG.bin
for more log.
