After suspend wakeup,HDMI can not display
Module: Jetson AGX Orin 32G/64G
software: Jetpack-6.2
after suspend wakeup,HDMI can not display
report rate 100%
error log:
evoc@tegra-ubuntu:~$ sudo systemctl start suspend.target
[sudo] password for evoc:
[ 1589.253941] sd 1:0:0:0: [sda] Synchronizing SCSI cache
[ 1589.254041] sd 1:0:0:0: [sda] Stopping disk
[ 1589.285570] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[ 1589.285581] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[ 1589.285586] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[ 1589.285593] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
??DCE RM Suspend rmStatus:0x0
??[ 1591.762575] IRQ286: set affinity failed(-22).
[ 1591.766033] IRQ286: set affinity failed(-22).
[ 1591.768939] IRQ286: set affinity failed(-22).
[ 1591.772049] IRQ286: set affinity failed(-22).
[ 1591.775503] IRQ286: set affinity failed(-22).
[ 1591.778776] IRQ286: set affinity failed(-22).
[ 1591.783125] IRQ286: set affinity failed(-22).
???clk_mach_suspend_early
clk_mach_suspend_early done
suspended vdd_core @ 950000uV
??spe entering sc7
??clk_mach_suspend
clk_mach_suspend done
fmon_suspend done
adc_suspend done
WAKE_MASK[31:0] = 0x21000100
WAKE_MASK[63:32] = 0x0
WAKE_MASK[95:64] = 0x17f200
TIER0[31:0] = 0x0
TIER0[63:32] = 0x0
TIER0[95:64] = 0x0
TIER1[31:0] = 0x0
TIER1[63:32] = 0x0
TIER1[95:64] = 0x0
TIER2[31:0] = 0x21000100
TIER2[63:32] = 0x0
TIER2[95:64] = 0x7f200
[1617.795] I> MB1 (version: 1.4.0.4-t234-54845784-82c7462e)
[1617.802] I> t234-A01-1-Silicon (0x12347) Prod
[1617.808] I> Boot-mode : SC7 Exit
[1617.812] I> Entry timestamp: 0x00000000
[1617.817] I> last_boot_error: 0x0
[1617.821] I> BR-BCT: preprod_dev_sign: 0
[1617.826] I> rst_source: 0xc, rst_level: 0x3
[1617.831] I> Task: SE error check
[1617.836] I> Task: Enable SLCG
[1617.839] I> Task: CRC check
[1617.843] I> Task: Crypto init
[1617.847] I> Task: NVRNG health check
[1617.852] I> NVRNG: Health check success
[1617.857] I> Task: MSS Bandwidth limiter settings for iGPU clients
[1617.864] I> Task: Verify SDRAM params
[1617.870] I> Task: MSS Encrypt status check
[1617.875] I> Task: NV_SC7 integrity check
[1617.885] I> Task: Initialize SOC Therm
[1617.890] I> Task: Program NV master stream id
[1617.895] I> Task: Verify boot mode
[1617.902] I> Task: Alias fuses
[1617.907] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[1617.915] I> Task: Print SKU type
[1617.920] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[1617.926] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[1617.932] I> FUSE_OPT_TPC_DISABLE = 0x00000080
[1617.937] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[1617.942] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[1617.948] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[1617.953] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[1617.959] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[1617.965] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[1617.970] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[1617.975] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[1617.981] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[1617.986] I> FUSE_SKU_INFO_0 = 0xd2
[1617.990] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[1617.996] I> FUSE_PACKAGE_INFO_0 = 0x2
[1618.000] I> SKU: Prod
[1618.004] I> Task: Boost clocks
[1618.008] I> Initializing NAFLL for BPMP_CPU_NIC.
[1618.014] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[1618.021] I> BPMP NAFLL lock success.
[1618.026] I> BPMP_CPU_NIC : src = 42, divisor = 0
[1618.032] I> Initializing PLLC2 for AXI_CBB.
[1618.037] I> AXI_CBB : src = 35, divisor = 0
[1618.042] I> Task: Voltage monitor
[1618.047] I> VMON: Vmon re-calibration and fine tuning done
[1618.053] I> Task: TSC init
[1618.057] I> Task: Thermal check
[1618.062] I> BCT max_tmon_limit = 105
[1618.066] I> BCT min_tmon_limit = -28
[1618.071] I> BCT max_tmon_limit = 105
[1618.076] I> BCT min_tmon_limit = -28
[1618.080] I> SKU specific max_chip_limit = 105
[1618.086] I> SKU specific min_chip_limit = -28
[1618.091] I> BCT max_chip_limit = 105
[1618.096] I> BCT min_chip_limit = -28
[1618.101] I> enable_soctherm_polling = 0
[1618.105] I> max temp read = 57
[1618.110] I> min temp read = 56
[1618.114] I> Enabling thermtrip
[1618.118] I> Task: Update FSI SCR with thermal fuse data
[1618.124] I> Task: Enable WDT 5th expiry
[1618.129] I> Task: I2C register
[1618.133] I> Task: Set I2C bus freq
[1618.138] I> Task: Reset FSI
[1618.141] I> Task: Pinmux init
[1618.150] I> skipped mmio_addr = 0xc2f10a0
[1618.156] I> skipped mmio_addr = 0xc2f10c0
[1618.162] I> skipped mmio_addr = 0xc2f1040
[1618.168] I> skipped mmio_addr = 0xc2f1080
[1618.174] I> skipped mmio_addr = 0xc2f1400
[1618.180] I> skipped mmio_addr = 0xc2f1420
[1618.185] I> skipped mmio_addr = 0xc2f1440
[1618.191] I> skipped mmio_addr = 0xc2f1460
[1618.197] I> skipped mmio_addr = 0xc2f1a00
[1618.203] I> skipped mmio_addr = 0xc2f1a20
[1618.209] I> skipped mmio_addr = 0xc2f1a60
[1618.215] I> skipped mmio_addr = 0xc2f1a6c
[1618.221] I> skipped mmio_addr = 0xc2f1a70
[1618.229] I> Task: Prod config init
[1618.233] I> Task: Pad voltage init
[1618.238] I> Task: Prod init
[1618.242] I> Task: Common rail init
[1618.248] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[1618.262] I> DONE: Thermal config
[1618.268] I> DONE: SOC rail config
[1618.273] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[1618.281] I> DONE: MEMIO rail config
[1618.286] I> DONE: GPU rail info
[1618.292] I> DONE: CV rail info
[1618.296] I> Task: Misc. board config
[1618.301] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[1618.308] I> Task: Enable clock-mon
[1618.324] I> FMON: Fmon re-programming done
[1618.329] I> Task: CCPLEX IST init
[1618.334] I> Task: CPU WP0
[1618.339] I> Loading MCE
[1618.351] I> Sending WP0 mailbox command to PSC
[1618.361] I> Task: MB1 fixed firewalls
[1618.388] I> Task: BPMP fw ast config
[1618.392] I> Task: Load nvdec-fw
[1618.410] I> Task: Program TSEC carveout
[1618.415] I> TSEC-FW load not enabled
[1618.420] I> Task: GPIO interrupt map
[1618.425] I> Task: Unpowergate AOPG CAN
[1618.429] I> Task: Misc NV security settings
[1618.435] I> NVDEC sticky bits programming done
[1618.441] I> Successfully powergated NVDEC
[1618.446] I> Task: Disable/Reload WDT
[1618.450] I> Task: Disable SCPM/POD reset
[1618.455] I> Task: Program BPMP-IPC carveouts
[1618.461] I> Program IPC carveouts
[1618.466] I> SLCG Global override status := 0x0
[1618.472] I> MB1: MSS reconfig completed
[1618.481] I> Program carveout CARVEOUT_TEMP_MB2RF before image load
I> MB2 (version: 0.0.0.0-t234-54845784-db255de9)
I> Emulation:
I> Entry timestamp: 0x6078a58e
I> Regular heap: [base:0x40040000, size:0x2000]
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: SMMU external bypass disable
I> Task: Enable hot-plug capability
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: OEM SC7 context integrity check
I> Task: Restore FSI padctl config
I> Task: Program CBB PCIE AMAP regions
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> Binary rce scrubbed successfully
W> FW header for binary dce not saved in context!
W> FW data for binary dce not saved in context!
W> Skip post read scrub for binary dce
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x82d200000
I> Binary ape scrubbed successfully
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x836000000
I> Binary xusb scrubbed successfully
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x838800000
I> Binary pva-fw scrubbed successfully
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x82d700000
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x82d980000
I> Task: Carveout setup
I> Scrub remaining OEM carveouts
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings
I> FSITHERM max temp = 58
I> FSITHERM min temp = 57
I> Task: Enable FSI SE clock
I> Enable FSI-SE clock…
I> Task: Initialize SBSA UART CAR
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Deinit UART
adc_resume done
clk_mach_resume
clk_mach_resume done
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
spe exiting sc7
??clk_mach_resume_late
I> Task: Trigger load FSI keyblob
I> Skipping FSI key blob copy
I> Task: Complete load FSI keyblob
I> Task: MB2-PSC_FW Key Manager Init
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d to psc
I> Received ACK from psc
I> Task: Unhalt FSI
I> FSI unhalt skipped
I> Task: Unhalt AUXPs
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalt??[ 1618.782909] Camera-FW o??clk_mach_resume_late done
??n t234-rce-safe started
TCU early console enabled.
??ing DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Task: Load HV/CPUBL
I> Task: Load TOS
DCE Started
DCE_R5_Init
??I> Task: Trigger load TSEC leyblob
??MPU enabled
DCE_SW_Init
??I> Sending opcode 0x53535452 to psc
I> Sent opcode to psc
I> Task: Disable MSS perf stats
I> Tas??STATUS_R[31:0] = 0x20000000
STATUS_R[63:32] = 0x0
STATUS_R[95:64] = 0x100000
??k: Program display sticky bits
I> Task: SMMU init
W> smmu ctx restore: addr is NULL!!
I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Lock fusing
I> MB2 finished
??NOTICE: tegra_soc_pwr_domain_on_finish: exited SC7 successfully. Entering normal world.
??[ 1618.954857] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 2.767 ms, total boot 174.923 ms)
??Admin Task Init
Admin Task Init complete
Print Task Init
RM Task Init
SHA Task Init
Admin Task Started
DCE SC7 SHA Enabled
RM Task Started
RM Task Running
Print Task Started
Print Task Running
SHA Task Started
SHA Task Running
DCE: FW Boot Complete
Admin Task Running
Starting RmBootstrap
Registered event_type:[0] for dce_core_ipc_type:[1]
Registered event_type:[1] for dce_core_ipc_type:??TCU debug prints will be routed to traces.
??[3]
dce_ipc State Initialized
RmBootstrap completed successfully
Resume RM
??[ 1593.598575] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[ 1593.598579] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[ 1593.598581] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[ 1593.598586] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[ 1593.598598] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 1593.838645] sd 1:0:0:0: [sda] Starting disk
??DCE RM resume rmStatus:0x0 ret:true
??[ 1594.320386] cpufreq: cpu4,cur:2008000,set:1728000,delta:280000,set ndiv:135
[ 1594.336502] thermal cooling_device10: hot-surface-alert cooling state: 1 → 0
[ 1603.169693] sd 1:0:0:0: [sda] Synchronizing SCSI cache
[ 1603.169782] sd 1:0:0:0: [sda] Stopping disk
[ 1603.259271] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[ 1603.259281] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[ 1603.259285] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[ 1603.259291] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
??[ 1608.419163] IRQ286: set affinity failed(-22).
[ 1608.422107] IRQ286: set affinity failed(-22).
[ 1608.424167] IRQ286: set affinity failed(-22).
[ 1608.425590] IRQ286: set affinity failed(-22).
[ 1608.427007] IRQ286: set affinity failed(-22).
[ 1608.429044] IRQ286: set affinity failed(-22).
[ 1608.431240] IRQ286: set affinity failed(-22).
??spe entering sc7
??clk_mach_suspend
fmon_suspend done
adc_suspend done
TIER0[31:0] = 0x0
TIER0[63:32] = 0x0
TIER0[95:64] = 0x0
TIER1[31:0] = 0x0
TIER1[63:32] = 0x0
TIER1[95:64] = 0x0
TIER2[63:32] = 0x0
[1641.421] I> MB1 (version: 1.4.0.4-t234-54845784-82c7462e)
[1641.428] I> t234-A01-1-Silicon (0x12347) Prod
[1641.433] I> Boot-mode : SC7 Exit
[1641.438] I> Entry timestamp: 0x00000000
[1641.443] I> last_boot_error: 0x0
[1641.447] I> BR-BCT: preprod_dev_sign: 0
[1641.452] I> rst_source: 0xc, rst_level: 0x3
[1641.457] I> Task: SE error check
[1641.461] I> Task: Enable SLCG
[1641.465] I> Task: CRC check
[1641.469] I> Task: Crypto init
[1641.473] I> Task: NVRNG health check
[1641.478] I> NVRNG: Health check success
[1641.483] I> Task: MSS Bandwidth limiter settings for iGPU clients
[1641.490] I> Task: Verify SDRAM params
[1641.496] I> Task: MSS Encrypt status check
[1641.501] I> Task: NV_SC7 integrity check
[1641.511] I> Task: Initialize SOC Therm
[1641.516] I> Task: Program NV master stream id
[1641.521] I> Task: Verify boot mode
[1641.528] I> Task: Alias fuses
[1641.534] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[1641.542] I> Task: Print SKU type
[1641.546] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[1641.553] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[1641.558] I> FUSE_OPT_TPC_DISABLE = 0x00000080
[1641.564] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[1641.569] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[1641.575] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[1641.580] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[1641.586] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[1641.591] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[1641.597] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[1641.602] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[1641.607] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[1641.613] I> FUSE_SKU_INFO_0 = 0xd2
[1641.617] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[1641.622] I> FUSE_PACKAGE_INFO_0 = 0x2
[1641.627] I> SKU: Prod
[1641.630] I> Task: Boost clocks
[1641.635] I> Initializing NAFLL for BPMP_CPU_NIC.
[1641.641] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[1641.648] I> BPMP NAFLL lock success.
[1641.653] I> BPMP_CPU_NIC : src = 42, divisor = 0
[1641.659] I> Initializing PLLC2 for AXI_CBB.
[1641.664] I> AXI_CBB : src = 35, divisor = 0
[1641.669] I> Task: Voltage monitor
[1641.674] I> VMON: Vmon re-calibration and fine tuning done
[1641.681] I> Task: TSC init
[1641.685] I> Task: Thermal check
[1641.689] I> BCT max_tmon_limit = 105
[1641.693] I> BCT min_tmon_limit = -28
[1641.698] I> BCT max_tmon_limit = 105
[1641.703] I> BCT min_tmon_limit = -28
[1641.707] I> SKU specific max_chip_limit = 105
[1641.713] I> SKU specific min_chip_limit = -28
[1641.718] I> BCT max_chip_limit = 105
[1641.723] I> BCT min_chip_limit = -28
[1641.728] I> enable_soctherm_polling = 0
[1641.733] I> max temp read = 57
[1641.737] I> min temp read = 56
[1641.741] I> Enabling thermtrip
[1641.745] I> Task: Update FSI SCR with thermal fuse data
[1641.751] I> Task: Enable WDT 5th expiry
[1641.756] I> Task: I2C register
[1641.760] I> Task: Set I2C bus freq
[1641.765] I> Task: Reset FSI
[1641.769] I> Task: Pinmux init
[1641.777] I> skipped mmio_addr = 0xc2f10a0
[1641.783] I> skipped mmio_addr = 0xc2f10c0
[1641.789] I> skipped mmio_addr = 0xc2f1040
[1641.795] I> skipped mmio_addr = 0xc2f1080
[1641.801] I> skipped mmio_addr = 0xc2f1400
[1641.807] I> skipped mmio_addr = 0xc2f1420
[1641.813] I> skipped mmio_addr = 0xc2f1440
[1641.819] I> skipped mmio_addr = 0xc2f1460
[1641.825] I> skipped mmio_addr = 0xc2f1a00
[1641.831] I> skipped mmio_addr = 0xc2f1a20
[1641.837] I> skipped mmio_addr = 0xc2f1a60
[1641.842] I> skipped mmio_addr = 0xc2f1a6c
[1641.848] I> skipped mmio_addr = 0xc2f1a70
[1641.856] I> Task: Prod config init
[1641.861] I> Task: Pad voltage init
[1641.865] I> Task: Prod init
[1641.870] I> Task: Common rail init
[1641.876] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[1641.889] I> DONE: Thermal config
[1641.895] I> DONE: SOC rail config
[1641.901] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[1641.909] I> DONE: MEMIO rail config
[1641.913] I> DONE: GPU rail info
[1641.919] I> DONE: CV rail info
[1641.923] I> Task: Misc. board config
[1641.929] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[1641.936] I> Task: Enable clock-mon
[1641.952] I> FMON: Fmon re-programming done
[1641.958] I> Task: CCPLEX IST init
[1641.962] I> Task: CPU WP0
[1641.968] I> Loading MCE
[1641.979] I> Sending WP0 mailbox command to PSC
[1641.989] I> Task: MB1 fixed firewalls
[1642.016] I> Task: BPMP fw ast config
[1642.021] I> Task: Load nvdec-fw
[1642.038] I> Task: Program TSEC carveout
[1642.043] I> TSEC-FW load not enabled
[1642.048] I> Task: GPIO interrupt map
[1642.053] I> Task: Unpowergate AOPG CAN
[1642.058] I> Task: Misc NV security settings
[1642.063] I> NVDEC sticky bits programming done
[1642.069] I> Successfully powergated NVDEC
[1642.074] I> Task: Disable/Reload WDT
[1642.079] I> Task: Disable SCPM/POD reset
[1642.084] I> Task: Program BPMP-IPC carveouts
[1642.089] I> Program IPC carveouts
[1642.095] I> SLCG Global override status := 0x0
[1642.101] I> MB1: MSS reconfig completed
[1642.110] I> Program carveout CARVEOUT_TEMP_MB2RF before image load
I> Emulation:
I> Entry timestamp: 0x61e13cf6
I> Unpowergate done
I> Powergating APE
I> Powergate done
adc_resume done
clk_mach_resume
spe exiting sc7
I> Task: Unhalt FSI
I> Unhalting RCE
I> Unhalt??[ 1642.416761] Camera-FW on t234-rce-safe??clk_mach_resume_late done
?? started
??ing DCE
I> Task: Load TOS
DCE Started
DCE_R5_Init
??MPU enabled
DCE_SW_In??I> Sending opcode 0x53535452 to psc
??it
??I> Sent opcode to psc
I> Task: Disable MSS perf stat??STATUS_R[31:0] = 0x20000000
??s
I> Task: Program display sticky bits
I> Task: SMMU init
I> MB2 finished
??[ 1642.588547] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 2.774 ms, total boot 174.767 ms)
??Admin Task Init
Print Task Init
RM Task Init
SHA Task Init
Admin Task Started
DCE SC7 SHA Enabled
RM Task Started
RM Task Running
Print Task Started
Print Task Running
SHA Task Started
Admin Task Running
SHA Task Running
??[ 1610.157262] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[ 1610.157267] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[ 1610.157271] tegra-ivc-bus bc00000.rt??[3]
Resume RM
??cpu:ivc-bus:dbg@2: ivc channel driver missing
[ 1610.157276] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[ 1610.399894] sd 1:0:0:0: [sda] Starting disk
??[ 1610.880395] cpufreq: cpu4,cur:2010000,set:1728000,delta:282000,set ndiv:135
evoc@tegra-ubuntu:~$ [ 1615.302239] nvgpu: 17000000.gpu nvgpu_os_fence_fdget:79 [ERR] error obtaining fence from fd 0
evoc@tegra-ubuntu:~$ [ 1623.053817] nvgpu: 17000000.gpu ga10b_pbdma_handle_intr_0_acquire:646 [ERR] semaphore acquire timeout!
[ 1623.053942] ga10b Channel Status - chip ga10b
[ 1623.053944] ga10b ---------------------------
[ 1623.053948] ga10b 508-ga10b, TSG: 3, pid 1771, thread name gnome-shell, refs: 3, deterministic: no, domain name: (no domain)
[ 1623.053950] ga10b channel status: in use on_pbdma, on_eng, pbdma_busy busy
[ 1623.053953] ga10b RAMFC: TOP: 8000002004008140 PUT: 002004008140 GET: 002004008140 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[ 1623.053955] ga10b
[ 1623.053957] ga10b 509-ga10b, TSG: 2, pid 1457, thread name Xorg, refs: 2, deterministic: no, domain name: (no domain)
[ 1623.053959] ga10b channel status: in use idle not busy
[ 1623.053961] ga10b RAMFC: TOP: 80000020040080c8 PUT: 0020040080c8 GET: 0020040080c8 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[ 1623.053962] ga10b
[ 1623.053964] ga10b 510-ga10b, TSG: 1, pid 1457, thread name Xorg, refs: 2, deterministic: no, domain name: (no domain)
[ 1623.053965] ga10b channel status: in use idle not busy
[ 1623.053967] ga10b RAMFC: TOP: 8000002004033398 PUT: 002004033398 GET: 002004033398 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004320000 payload 0000000000000000 execute 00000001
[ 1623.053968] ga10b
[ 1623.053969] ga10b 511-ga10b, TSG: 0, pid 1457, thread name Xorg, refs: 2, deterministic: no, domain name: (no domain)
[ 1623.053970] ga10b channel status: in use idle not busy
[ 1623.053972] ga10b RAMFC: TOP: 800000200405d1f0 PUT: 00200405d1f0 GET: 00200405d1f0 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004020000 payload 0000000000000000 execute 00100001
[ 1623.053973] ga10b
[ 1623.053976] ga10b PBDMA Status - chip ga10b
[ 1623.053977] ga10b -------------------------
[ 1623.053980] ga10b pbdma 0:
[ 1623.053983] ga10b id: 3 - [tsg] next_id: - -1 [channel] | status: valid
[ 1623.053988] ga10b PBDMA_PUT 0000001ffd140ea4 PBDMA_GET 0000001ffd140e90
[ 1623.053994] ga10b GP_PUT 000004bd GP_GET 000004ba FETCH 000004bd HEADER 2140006c
[ 1623.054000] ga10b HDR 2001001b SHADOW0 fd140e80 SHADOW1 0000241f
[ 1623.054002] ga10b pbdma 1:
[ 1623.054003] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1623.054008] ga10b PBDMA_PUT 00000093371b3484 PBDMA_GET 00000093371b3484
[ 1623.054014] ga10b GP_PUT 00000000 GP_GET 263687b0 FETCH 00000000 HEADER e113b1fc
[ 1623.054018] ga10b HDR 8179192d SHADOW0 171224ad SHADOW1 f8d2b104
[ 1623.054020] ga10b pbdma 2:
[ 1623.054021] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1623.054027] ga10b PBDMA_PUT 000000bef026b7fc PBDMA_GET 000000d5dd7fb440
[ 1623.054032] ga10b GP_PUT 00000000 GP_GET 8346fbcf FETCH 00000000 HEADER a0037af8
[ 1623.054036] ga10b HDR 5b6dbf5d SHADOW0 adc97323 SHADOW1 7d3c2f58
[ 1623.054038] ga10b pbdma 3:
[ 1623.054039] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1623.054045] ga10b PBDMA_PUT 000000f7d7f2cef8 PBDMA_GET 000000ceed0f970c
[ 1623.054050] ga10b GP_PUT 00000000 GP_GET 14797e95 FETCH 00000000 HEADER a105fcd8
[ 1623.054055] ga10b HDR 9c3ba584 SHADOW0 2681e257 SHADOW1 dd8a0659
[ 1623.054057] ga10b pbdma 4:
[ 1623.054057] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1623.054063] ga10b PBDMA_PUT 000000bb623c56d8 PBDMA_GET 000000bb623c56d8
[ 1623.054068] ga10b GP_PUT 00000000 GP_GET 2e192871 FETCH 00000000 HEADER 41d1a1e8
[ 1623.054072] ga10b HDR d4741734 SHADOW0 b85c61ee SHADOW1 b637efc7
[ 1623.054074] ga10b pbdma 5:
[ 1623.054075] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1623.054080] ga10b PBDMA_PUT 000000d955ab3bdc PBDMA_GET 000000d955ab3bdc
[ 1623.054086] ga10b GP_PUT 00000000 GP_GET 6b565c5c FETCH 00000000 HEADER e081ddcc
[ 1623.054090] ga10b HDR 6dbd03eb SHADOW0 9561e174 SHADOW1 7fdc0eb2
[ 1623.054091] ga10b
[ 1623.054096] ga10b ga10b eng 0:
[ 1623.054097] ga10b id: 3 (tsg), next_id: -1 (channel), ctx status: valid
[ 1623.054098] ga10b
[ 1623.054101] ga10b ga10b eng 1:
[ 1623.054102] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1623.054103] ga10b
[ 1623.054106] ga10b ga10b eng 2:
[ 1623.054106] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1623.054107] ga10b
[ 1623.054111] ga10b ga10b eng 3:
[ 1623.054112] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1623.054115] ga10b ga10b eng 4:
[ 1623.054116] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1623.054117] ga10b
[ 1623.054120] ga10b ga10b eng 5:
[ 1623.054121] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1623.054122] ga10b
[ 1623.054123] nvgpu: 17000000.gpu ga10b_pbdma_report_error:330 [ERR] pbdma_intr_0(0)= 0x04000000
[ 1623.054147] nvgpu: 17000000.gpu nvgpu_cic_mon_report_err_safety_services:97 [ERR] Error reporting is not supported in this platform
[ 1623.054156] nvgpu: 17000000.gpu nvgpu_set_err_notifier_locked:143 [ERR] error notifier set to 24 for ch 508 owned by gnome-shell
[ 1632.374483] nvgpu: 17000000.gpu ga10b_pbdma_handle_intr_0_acquire:646 [ERR] semaphore acquire timeout!
[ 1632.374560] ga10b Channel Status - chip ga10b
[ 1632.374561] ga10b ---------------------------
[ 1632.374565] ga10b 508-ga10b, TSG: 3, pid 1771, thread name gnome-shell, refs: 3, deterministic: no, domain name: (no domain)
[ 1632.374566] ga10b channel status: in use on_pbdma, on_eng, pbdma_busy busy
[ 1632.374569] ga10b RAMFC: TOP: 8000002004008140 PUT: 002004008140 GET: 002004008140 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[ 1632.374571] ga10b
[ 1632.374573] ga10b 509-ga10b, TSG: 2, pid 1457, thread name Xorg, refs: 2, deterministic: no, domain name: (no domain)
[ 1632.374574] ga10b channel status: in use idle not busy
[ 1632.374576] ga10b RAMFC: TOP: 80000020040080c8 PUT: 0020040080c8 GET: 0020040080c8 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[ 1632.374577] ga10b
[ 1632.374578] ga10b 510-ga10b, TSG: 1, pid 1457, thread name Xorg, refs: 2, deterministic: no, domain name: (no domain)
[ 1632.374579] ga10b channel status: in use idle not busy
[ 1632.374581] ga10b RAMFC: TOP: 80000020040334d8 PUT: 0020040334d8 GET: 0020040334d8 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004320000 payload 0000000000000000 execute 00000001
[ 1632.374582] ga10b
[ 1632.374584] ga10b 511-ga10b, TSG: 0, pid 1457, thread name Xorg, refs: 2, deterministic: no, domain name: (no domain)
[ 1632.374585] ga10b channel status: in use idle not busy
[ 1632.374586] ga10b RAMFC: TOP: 800000200405d628 PUT: 00200405d628 GET: 00200405d628 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004020000 payload 0000000000000000 execute 00100001
[ 1632.374588] ga10b
[ 1632.374590] ga10b PBDMA Status - chip ga10b
[ 1632.374592] ga10b -------------------------
[ 1632.374594] ga10b pbdma 0:
[ 1632.374597] ga10b id: 3 - [tsg] next_id: - -1 [channel] | status: valid
[ 1632.374603] ga10b PBDMA_PUT 0000001ffd140ea4 PBDMA_GET 0000001ffd140e90
[ 1632.374609] ga10b GP_PUT 000004bd GP_GET 000004ba FETCH 000004bd HEADER 2140006c
[ 1632.374614] ga10b HDR 2001001b SHADOW0 fd140e80 SHADOW1 0000241f
[ 1632.374616] ga10b pbdma 1:
[ 1632.374617] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1632.374623] ga10b PBDMA_PUT 00000093331b3c84 PBDMA_GET 00000093331b3c84
[ 1632.374630] ga10b GP_PUT 00000000 GP_GET 263687b0 FETCH 00000000 HEADER e113b1fc
[ 1632.374635] ga10b HDR 0979092d SHADOW0 175224ad SHADOW1 f8dab104
[ 1632.374665] ga10b pbdma 2:
[ 1632.374667] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1632.374673] ga10b PBDMA_PUT 000000bef0a6b7fc PBDMA_GET 000000c5dd7fb440
[ 1632.374678] ga10b GP_PUT 00000000 GP_GET 8346fbcf FETCH 00000000 HEADER a0037af8
[ 1632.374683] ga10b HDR 5b6dbf5d SHADOW0 adcd7323 SHADOW1 7d3d2f58
[ 1632.374685] ga10b pbdma 3:
[ 1632.374686] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1632.374692] ga10b PBDMA_PUT 000000f7d7f2cef8 PBDMA_GET 000000ce6d07970c
[ 1632.374698] ga10b GP_PUT 00000000 GP_GET 14787f95 FETCH 00000000 HEADER a105fcd8
[ 1632.374702] ga10b HDR 9cbba584 SHADOW0 26817257 SHADOW1 dd8a0651
[ 1632.374704] ga10b pbdma 4:
[ 1632.374705] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1632.374711] ga10b PBDMA_PUT 000000fb623c16d8 PBDMA_GET 000000fb623c16d8
[ 1632.374716] ga10b GP_PUT 00000000 GP_GET 3e192871 FETCH 00000000 HEADER 41d1a1e8
[ 1632.374721] ga10b HDR c4741774 SHADOW0 b85c61ee SHADOW1 b6376f47
[ 1632.374723] ga10b pbdma 5:
[ 1632.374724] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1632.374729] ga10b PBDMA_PUT 000000d955a33fdc PBDMA_GET 000000d955a33fdc
[ 1632.374735] ga10b GP_PUT 00000000 GP_GET 6b565c5c FETCH 00000000 HEADER e081ddcc
[ 1632.374739] ga10b HDR 6dbd1beb SHADOW0 9161e958 SHADOW1 7fdc0eba
[ 1632.374740] ga10b
[ 1632.374745] ga10b ga10b eng 0:
[ 1632.374747] ga10b id: 3 (tsg), next_id: -1 (channel), ctx status: valid
[ 1632.374748] ga10b
[ 1632.374751] ga10b ga10b eng 1:
[ 1632.374752] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1632.374753] ga10b
[ 1632.374756] ga10b ga10b eng 2:
[ 1632.374757] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1632.374758] ga10b
[ 1632.374761] ga10b ga10b eng 3:
[ 1632.374762] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1632.374763] ga10b
[ 1632.374766] ga10b ga10b eng 4:
[ 1632.374767] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1632.374768] ga10b
[ 1632.374771] ga10b ga10b eng 5:
[ 1632.374772] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1632.374773] ga10b
[ 1632.374774] ga10b
[ 1632.374775] nvgpu: 17000000.gpu ga10b_pbdma_report_error:330 [ERR] pbdma_intr_0(0)= 0x04000000
[ 1632.374798] nvgpu: 17000000.gpu nvgpu_cic_mon_report_err_safety_services:97 [ERR] Error reporting is not supported in this platform
[ 1632.374807] nvgpu: 17000000.gpu nvgpu_set_err_notifier_locked:143 [ERR] error notifier set to 24 for ch 508 owned by gnome-shell
[ 1641.447995] nvgpu: 17000000.gpu ga10b_pbdma_handle_intr_0_acquire:646 [ERR] semaphore acquire timeout!
[ 1641.448059] ga10b Channel Status - chip ga10b
[ 1641.448061] ga10b ---------------------------
[ 1641.448064] ga10b 508-ga10b, TSG: 3, pid 1771, thread name gnome-shell, refs: 3, deterministic: no, domain name: (no domain)
[ 1641.448065] ga10b channel status: in use on_pbdma, on_eng, pbdma_busy busy
[ 1641.448067] ga10b RAMFC: TOP: 8000002004008140 PUT: 002004008140 GET: 002004008140 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[ 1641.448069] ga10b
[ 1641.448071] ga10b 509-ga10b, TSG: 2, pid 1457, thread name Xorg, refs: 2, deterministic: no, domain name: (no domain)
[ 1641.448072] ga10b channel status: in use idle not busy
[ 1641.448074] ga10b RAMFC: TOP: 80000020040080c8 PUT: 0020040080c8 GET: 0020040080c8 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[ 1641.448075] ga10b
[ 1641.448076] ga10b 510-ga10b, TSG: 1, pid 1457, thread name Xorg, refs: 2, deterministic: no, domain name: (no domain)
[ 1641.448078] ga10b channel status: in use idle not busy
[ 1641.448079] ga10b RAMFC: TOP: 8000002004033618 PUT: 002004033618 GET: 002004033618 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004320000 payload 0000000000000000 execute 00000001
[ 1641.448080] ga10b
[ 1641.448081] ga10b 511-ga10b, TSG: 0, pid 1457, thread name Xorg, refs: 2, deterministic: no, domain name: (no domain)
[ 1641.448082] ga10b channel status: in use idle not busy
[ 1641.448083] ga10b RAMFC: TOP: 800000200405da60 PUT: 00200405da60 GET: 00200405da60 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004020000 payload 0000000000000000 execute 00100001
[ 1641.448084] ga10b
[ 1641.448087] ga10b PBDMA Status - chip ga10b
[ 1641.448088] ga10b -------------------------
[ 1641.448090] ga10b pbdma 0:
[ 1641.448093] ga10b id: 3 - [tsg] next_id: - -1 [channel] | status: valid
[ 1641.448099] ga10b PBDMA_PUT 0000001ffd13f284 PBDMA_GET 0000001ffd13f270
[ 1641.448104] ga10b GP_PUT 000004c5 GP_GET 000004c2 FETCH 000004c5 HEADER 2140006c
[ 1641.448109] ga10b HDR 2001001b SHADOW0 fd13f260 SHADOW1 0000241f
[ 1641.448111] ga10b pbdma 1:
[ 1641.448112] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1641.448117] ga10b PBDMA_PUT 00000093331a3c84 PBDMA_GET 00000093331a3c84
[ 1641.448122] ga10b GP_PUT 00000000 GP_GET 263687b0 FETCH 00000000 HEADER e113b1fc
[ 1641.448127] ga10b HDR 8179192d SHADOW0 171224ad SHADOW1 f8dab104
[ 1641.448129] ga10b pbdma 2:
[ 1641.448130] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1641.448135] ga10b PBDMA_PUT 000000bef0a6b7fc PBDMA_GET 000000c59d7fb440
[ 1641.448141] ga10b GP_PUT 00000000 GP_GET 0346fbcf FETCH 00000000 HEADER a0037af8
[ 1641.448145] ga10b HDR 5a6dbf5d SHADOW0 adcd7303 SHADOW1 7d3c2f58
[ 1641.448147] ga10b pbdma 3:
[ 1641.448148] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1641.448153] ga10b PBDMA_PUT 000000f7d7f2eef8 PBDMA_GET 000000ce6d07960c
[ 1641.448159] ga10b GP_PUT 00000000 GP_GET 14787f9d FETCH 00000000 HEADER a105fcdc
[ 1641.448163] ga10b HDR 9cbba584 SHADOW0 2681f257 SHADOW1 dd8a0651
[ 1641.448165] ga10b pbdma 4:
[ 1641.448166] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1641.448171] ga10b PBDMA_PUT 000000bb623c56d8 PBDMA_GET 000000bb623c56d8
[ 1641.448177] ga10b GP_PUT 00000000 GP_GET 2e196873 FETCH 00000000 HEADER 41d1e1e8
[ 1641.448181] ga10b HDR c4741774 SHADOW0 b81c61ee SHADOW1 b637ef47
[ 1641.448183] ga10b pbdma 5:
[ 1641.448184] ga10b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1641.448189] ga10b PBDMA_PUT 000000d955a33bdc PBDMA_GET 000000d955a33bdc
[ 1641.448194] ga10b GP_PUT 00000000 GP_GET 6b565c5c FETCH 00000000 HEADER 6081ddcc
[ 1641.448198] ga10b HDR 6dbd1aeb SHADOW0 9561e178 SHADOW1 7fde0eba
[ 1641.448199] ga10b
[ 1641.448205] ga10b ga10b eng 0:
[ 1641.448206] ga10b id: 3 (tsg), next_id: -1 (channel), ctx status: valid
[ 1641.448207] ga10b
[ 1641.448210] ga10b ga10b eng 1:
[ 1641.448211] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1641.448212] ga10b
[ 1641.448215] ga10b ga10b eng 2:
[ 1641.448216] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1641.448220] ga10b ga10b eng 3:
[ 1641.448221] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1641.448224] ga10b ga10b eng 4:
[ 1641.448225] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1641.448226] ga10b
[ 1641.448230] ga10b ga10b eng 5:
[ 1641.448231] ga10b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1641.448232] ga10b
[ 1641.448234] nvgpu: 17000000.gpu ga10b_pbdma_report_error:330 [ERR] pbdma_intr_0(0)= 0x04000000
[ 1641.448240] nvgpu: 17000000.gpu nvgpu_cic_mon_report_err_safety_services:97 [ERR] Error reporting is not supported in this platform
[ 1641.448249] nvgpu: 17000000.gpu nvgpu_set_err_notifier_locked:143 [ERR] error notifier set to 24 for ch 508 owned by gnome-shell
Can issue be reproduced with any HDMI dusplay or just specific display?
It is a known issue on 36.4.3 and will be fixed in 36.5 release.
