AGX Orin 64G(DG4064型号eMMC)版本使用中出现mmc0故障报警导致系统卡死
Hi,我们这边在使用AGX Orin 64G(emmc型号DG4064)版本时出现了如下mmc故障报错,目前发现 在启动阶段出现的概率很高,在正常工作过程中也会小概率出现,Debug口输出的故障信息如下:
[57657.004920] WARNING: CPU: 8 PID: 123 at drivers/mmc/host/cqhci.c:1071 cqhci_0
[57657.014757] ---[ end trace b8b81fbd4983b9b2 ]---
[57657.019560] blk_update_request: I/O error, dev mmcblk0, sector 3050048 op 0x0
[57657.031078] Buffer I/O error on dev mmcblk0p1, logical block 0, lost sync pae
[57657.039150] EXT4-fs (mmcblk0p1): I/O error while writing superblock
[57657.039213] mmc0: cqhci: CQE failed to exit halt state
[57657.039369] EXT4-fs (mmcblk0p1): previous I/O error to superblock detected
[57657.045713] EXT4-fs error (device mmcblk0p1): ext4_dirty_inode:6002: inode #r
[57718.216890] mmc0: cqhci: timeout for tag 17
[57718.221206] mmc0: cqhci: ============ CQHCI REGISTER DUMP ===========
[57718.227841] mmc0: cqhci: Caps:      0x000020c8 | Version:  0x00000510
[57718.234483] mmc0: cqhci: Config:    0x00000001 | Control:  0x00000100
[57718.241110] mmc0: cqhci: Int stat:  0x00000000 | Int enab: 0x00000006
[57718.247750] mmc0: cqhci: Int sig:   0x00000006 | Int Coal: 0x00000000
[57718.254379] mmc0: cqhci: TDL base:  0x00000000 | TDL up32: 0x00000000
[57718.261006] mmc0: cqhci: Doorbell:  0x001e0000 | TCN:      0x00000000
[57718.267643] mmc0: cqhci: Dev queue: 0x00000000 | Dev Pend: 0x00000000
[57718.274265] mmc0: cqhci: Task clr:  0x00000000 | SSC1:     0x00001000
[57718.280903] mmc0: cqhci: SSC2:      0x00000000 | DCMD rsp: 0x00000800
[57718.287529] mmc0: cqhci: RED mask:  0xfdf9a080 | TERRI:    0x002f000d
[57718.294170] mmc0: cqhci: Resp idx:  0x0000002e | Resp arg: 0x00000900
[57718.300811] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[57718.307451] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00000505
[57718.314092] mmc0: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[57718.320731] mmc0: sdhci: Argument:  0x00010000 | Trn mode: 0x00000023
[57718.327355] mmc0: sdhci: Present:   0x01fb00f0 | Host ctl: 0x00000038
[57718.333993] mmc0: sdhci: Power:     0x00000001 | Blk gap:  0x00000000
[57718.340635] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000000f
[57718.347257] mmc0: sdhci: Timeout:   0x0000000e | Int stat: 0x00000000
[57718.353894] mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00fc0003
[57718.360530] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[57718.367169] mmc0: sdhci: Caps:      0x3f6cd08c | Caps_1:   0x18002f73
[57718.373815] mmc0: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[57718.380454] mmc0: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x0400658d
[57718.387077] mmc0: sdhci: Resp[2]:   0x0fc30000 | Resp[3]:  0x00000240
[57718.393718] mmc0: sdhci: Host ctl2: 0x0000300d
[57718.398297] mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000007fffffe210
[57718.405674] mmc0: sdhci: ============================================
[57718.412313] mmc0: running CQE recovery
[57718.428886] CPU:0, Error: cbb-fabric@0x13a00000, irq=32
之前Nvidia反馈使用Jetpack 5.1.4验证,目前发现使用Jetpack512和Jetpack514都会出现这个问题
但是之前使用G1M15M这个型号的emmc的Orin模组是没有这个问题的
另外有一个信息是,使用fsck检查mmcblk0p1会有如下报警信息:麻烦看是否会对emmc工作有影响
fsck.log (1.5 KB)
上次出现问题的topic: “mmc0: cache flush error -110” during Orin work
详细的mmc故障日志:
mmc_fault.log (30.4 KB)
Could you put the module into NV devkit and reproduce this with jetpack6.1?
Hi 您好,
我们把一颗Orin模块升级到了6.1在我们自己的硬件环境上进行复现,目前还未出现;同时我们自己的5.1.2的固件版本也在Nvidia开发板上做过重启验证,同样也复现了问题
不过,我们查看了DG4064这个型号eMMC的PCN(210100)变更说明,应该是Jetpack5.1.2是做过适配的,如下图
请问下,是否有哪些烧录环境的配置参数可能会导致这个问题吗,我们是否可以检查或者修改哪些烧录环境的参数来定位这个问题呢?
There was a old known issue for sdcard. But I think it should happen to eMMC as well as SDIO and SDMMC are sharing the same driver.
您好,升级6.1的的变动有点大,我们需要一些时间进行适配
请问下,此类问题是否还有其他的方式进行修复,比如5.1.2上是否有针对这个问题的补丁呢?可以作为一个过渡方案
for rel-35.6, please try these two patches.
patch 1:
diff --git a/drivers/iommu/io-pgtable-arm.c b/drivers/iommu/io-pgtable-arm.c
index 421c670..350d706 100644
--- a/drivers/iommu/io-pgtable-arm.c
+++ b/drivers/iommu/io-pgtable-arm.c
@@ -242,13 +242,15 @@
 				   sizeof(*ptep) * num_entries, DMA_TO_DEVICE);
-static void __arm_lpae_clear_pte(arm_lpae_iopte *ptep, struct io_pgtable_cfg *cfg)
+static void __arm_lpae_clear_pte(arm_lpae_iopte *ptep, struct io_pgtable_cfg *cfg, int num_entries)
+	int i;
-	*ptep = 0;
+	for (i = 0; i < num_entries; i++)
+		ptep[i] = 0;
-	if (!cfg->coherent_walk)
-		__arm_lpae_sync_pte(ptep, 1, cfg);
+	if (!cfg->coherent_walk && num_entries)
+		__arm_lpae_sync_pte(ptep, num_entries, cfg);
 static size_t __arm_lpae_unmap(struct arm_lpae_io_pgtable *data,
@@ -610,7 +612,7 @@
 	arm_lpae_iopte pte;
 	struct io_pgtable *iop = &data->iop;
-	int i = 0, num_entries, max_entries, unmap_idx_start;
+	int i = 0, j = 0, num_entries, max_entries, unmap_idx_start;
 	/* Something went horribly wrong and we ran out of page table */
 	if (WARN_ON(lvl == ARM_LPAE_MAX_LEVELS))
@@ -627,33 +629,28 @@
 		max_entries = ARM_LPAE_PTES_PER_TABLE(data) - unmap_idx_start;
 		num_entries = min_t(int, pgcount, max_entries);
-		while (i < num_entries) {
-			pte = READ_ONCE(*ptep);
+		/* Find and handle non-leaf entries */
+		for (i = 0; i < num_entries; i++) {
+			pte = READ_ONCE(ptep[i]);
 			if (WARN_ON(!pte))
 				break;
-			__arm_lpae_clear_pte(ptep, &iop->cfg);
 			if (!iopte_leaf(pte, lvl, iop->fmt)) {
+				__arm_lpae_clear_pte(&ptep[i], &iop->cfg, 1);
 				/* Also flush any partial walks */
 				io_pgtable_tlb_flush_walk(iop, iova + i * size, size,
 							  ARM_LPAE_GRANULE(data));
 				__arm_lpae_free_pgtable(data, lvl + 1, iopte_deref(pte, data));
-			} else if (iop->cfg.quirks & IO_PGTABLE_QUIRK_NON_STRICT) {
-				 * Order the PTE update against queueing the IOVA, to
-				 * guarantee that a flush callback from a different CPU
-				 * has observed it before the TLBIALL can be issued.
-				smp_wmb();
-			} else {
-				io_pgtable_tlb_add_page(iop, gather, iova + i * size, size);
-			ptep++;
-			i++;
+		/* Clear the remaining entries */
+		__arm_lpae_clear_pte(ptep, &iop->cfg, i);
+		for (j = 0; j < i; j++)
+			io_pgtable_tlb_add_page(iop, gather, iova + j * size, size);
 		return i * size;
 	} else if (iopte_leaf(pte, lvl, iop->fmt)) {
patch2:
index 497c703..421c670 100644
@@ -242,15 +242,13 @@
-static void __arm_lpae_clear_pte(arm_lpae_iopte *ptep, struct io_pgtable_cfg *cfg, int num_entries)
+static void __arm_lpae_clear_pte(arm_lpae_iopte *ptep, struct io_pgtable_cfg *cfg)
-	int i;
-	for (i = 0; i < num_entries; i++)
-		ptep[i] = 0;
+	*ptep = 0;
-		__arm_lpae_sync_pte(ptep, num_entries, cfg);
+		__arm_lpae_sync_pte(ptep, 1, cfg);
@@ -629,15 +627,13 @@
-		if (WARN_ON(!pte))
-			return 0;
-		__arm_lpae_clear_pte(ptep, &iop->cfg, num_entries);
+			pte = READ_ONCE(*ptep);
 			if (WARN_ON(!pte))
 				break;
+			__arm_lpae_clear_pte(ptep, &iop->cfg);
您好,请问下,是否有针对35.4.1的patch呢?
目前我们批量使用的是 Jetson Linux 35.4.1的版本。
您好,我们在35.6上打了这两个patch,使用nvbuild.sh编译了新的内核文件,并替换到升级了5.1.4的公版固件的Orin模组内,进行reboot压力测试,目前依然还是复现了mmc的问题.
但是我们使用6.1的公版固件,进行压力测试目前已经进行了约1周的时间,没有复现,看样子6.1上应该是修复这个问题,请问下是否有其他的patch修复这个问题
Hi all
We had the same issue with Jetpack 5.1.2 on attachment file.
We use the Orin AGX 64G module with the suffix code 501 after PCN210100.
And according to the information from the following website, t234-pcn210100-emmc-35.4.1.tbz2 and t234-dram-package-35.4.1_2024-09-18.tbz2 were added to the BSP and burned, and a reboot test was performed.
This issue occurred on 3 out of 20 platforms using Orin AGX 64G.
This case cannot be upgraded to Jetpack 6.1 or above. Can you give us a fix for Jetpack 5.1.2?
EMMC_error.txt (130.5 KB)
HI
Have you finally sovled this issue?We met the same err in Jetpack 5.1.x?
Hi yangbin.fang
The Orin AGX 64G still has problems with the Jetpack 5.1.2 BSP on the Devkit.
We tried Jetpack 5.1.5, which seemed to solve the problem, but after a lot of testing, the problem still exists, but it is less severe than Jetpack 5.1.2.
The amazing thing is that Jetpack 5.1.5 has no problems on the Devkit, but we don’t have so many Devkits to reboot at the same time, so we can’t be sure that the Devkit is OK.
Since our custom board environment needs to be fixed in Jetpack 5.1.2, I back-ported the eMMC Driver of Jetpack 5.1.5 to Jetpack 5.1.2, and the eMMC problem has now been reduced to about one thousandth.
The log message in the attachment still occurs.
8 log 1.txt (33.6 KB)
Hi, Have you found which patch can fix it? We met the same error in jetpack-6.0
