I use jetson linux r36.5 to bring up my carrier board, only 8 cpus online, others offline, how to fix it? thanks
root@tegra-ubuntu:~# lscpu
Architecture: aarch64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 12
On-line CPU(s) list: 0-7
Off-line CPU(s) list: 8-11
Vendor ID: ARM
Model name: Cortex-A78AE
Model: 1
Thread(s) per core: 1
Core(s) per cluster: 4
Socket(s): 1
Cluster(s): 2
Stepping: r0p1
CPU max MHz: 2201.6001
CPU min MHz: 115.2000
BogoMIPS: 62.50
Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics
fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp usc
at ilrcpc flagm paca pacg
Caches (sum of all):
L1d: 512 KiB (8 instances)
L1i: 512 KiB (8 instances)
L2: 2 MiB (8 instances)
L3: 4 MiB (2 instances)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-7
Vulnerabilities:
Gather data sampling: Not affected
Indirect target selection: Not affected
Itlb multihit: Not affected
L1tf: Not affected
Mds: Not affected
Meltdown: Not affected
Mmio stale data: Not affected
Reg file data sampling: Not affected
Retbleed: Not affected
Spec rstack overflow: Not affected
Spec store bypass: Mitigation; Speculative Store Bypass disabled via p
rctl
Spectre v1: Mitigation; __user pointer sanitization
Spectre v2: Mitigation; CSV2, BHB
Srbds: Not affected
Tsx async abort: Not affected
