I have a xavier. It’s only 4 CPUs online .
I down’t know how to bring up the 4~7 CPUs .
Here is the dmsg
~$ sudo dmesg |grep CPU
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.529560] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.577132] CPU1: Booted secondary processor [4e0f0040]
[ 0.609197] CPU2: Booted secondary processor [4e0f0040]
[ 0.641338] CPU3: Booted secondary processor [4e0f0040]
[ 0.673554] CPU4: Booted secondary processor [4e0f0040]
[ 0.705802] CPU5: Booted secondary processor [4e0f0040]
[ 0.738193] CPU6: Booted secondary processor [4e0f0040]
[ 0.770477] CPU7: Booted secondary processor [4e0f0040]
[ 0.772611] Brought up 8 CPUs
[ 0.773192] CPU features: detected feature: Privileged Access Never
[ 0.773225] CPU features: detected feature: LSE atomic instructions
[ 0.773254] CPU features: detected feature: User Access Override
[ 0.773286] CPU features: detected feature: 32-bit EL0 Support
[ 0.778330] CPU: All CPU(s) started at EL2
[ 1.275203] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 15.581004] tegra186-cam-rtcpu bc00000.rtcpu: RTCPU coverage: IOVM setup error : 4294967291
[ 15.614902] tegra186-cam-rtcpu bc00000.rtcpu: (expected if RTCPU was not built with coverage enabled)
[ 15.989166] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (69)
[ 30.146347] CPU4: shutdown
[ 30.182962] psci: CPU4 killed.
[ 30.226511] CPU5: shutdown
[ 30.243305] psci: CPU5 killed.
[ 30.287113] CPU6: shutdown
[ 30.321205] psci: CPU6 killed.
[ 30.374242] CPU7: shutdown
[ 30.374364] psci: CPU7 killed.
sudo ./jetson_clocks.sh --show
SOC family:tegra194 Machine:jetson-xavier
Online CPUs: 0-3
CPU Cluster Switching: Disabled
cpu0: Gonvernor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400
cpu1: Gonvernor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400
cpu2: Gonvernor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400
cpu3: Gonvernor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400
cpu4: Gonvernor=schedutil MinFreq=115200 MaxFreq=2265600 CurrentFreq=2265600
cpu5: Gonvernor=schedutil MinFreq=115200 MaxFreq=2265600 CurrentFreq=2265600
cpu6: Gonvernor=schedutil MinFreq=115200 MaxFreq=2265600 CurrentFreq=2265600
cpu7: Gonvernor=schedutil MinFreq=115200 MaxFreq=2265600 CurrentFreq=2265600
GPU MinFreq=114750000 MaxFreq=675750000 CurrentFreq=114750000
EMC MinFreq=204000000 MaxFreq=1331200000 CurrentFreq=665600000 FreqOverride=0
Fan: speed=0
