AGX Orin Developer Kit not booting due to `PSC_MAILBOX: Failed to send opcode`
Hi NVIDIA,
I have an NVIDIA Jetson AGX Orin Developer Kit that was working normally, running my application and peripherals without any issues. One day, it suddenly stopped booting.
The board powers on, but it never reaches Linux. I connected the debug UART and captured the boot output.
The same sequence repeats thrice.
[0000.063] I> MB1 (version: 1.0.1.17-t234-54845784-9b0d5809)
[0000.069] I> t234-A01-1-Silicon (0x12347) Prod
[0000.073] I> Boot-mode : Coldboot
[0000.076] I> Entry timestamp: 0x00000000
[0000.080] I> last_boot_error: 0xc1c00606
[0000.084] I> BR-BCT: preprod_dev_sign: 0
[0000.088] C> rst_source: 0x17, rst_lev -  BR-BCT based selection
[0000.099] I> Default chain: 1|B
[0000.102] I> Task: SE error check
[0000.105] I> Task: Bootchain select WAR set
[0000.109] I> Task: Update Boot chain markers
[0000.113] I> Task: Send error information to MCU
[0000.118] I> Task: Enable SLCG
[0000.121] I> Task: CRC check
[0000.124] I> Task: Initialize MB2 params
[0000.127] I> MB2-params @ 0x4006001] I> NVRNG: Health check success
[0000.145] I> Task: Check ECID against ECID in fuses
[0000.150] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.156] I> Task: Enabling and iconfigure MBWT settings for any PC!
[0000.168] I> Task: Secure debug controls
[0000.171] I> Task: strap war set
[0000.175] I> Task: Initialize SOC Therm
[0000.178] I> Task: Program NV master stream id
[0000.183] I> Task: Verify boot mode
[0000.387] E> PSC_MAILBOX: Failed to send opcode.
[0000.391] C> Task 0x16 failed (err: 0xc1c00606)
[0000.396] E> Top caller module: MB1_PSC, error module: PSC_MAILBOX, reason: 0x06, aux_info: 0x06
[0000.404] C> Boot Info Table status dump :
0111111111001110001111
After this, the board restarts and the exact same sequence occurs again.
Current observations
  • The board powers on normally.
  • The debug UART is working.
  • The board reaches MB1 successfully.
  • MB1 performs several initialization tasks successfully.
  • It consistently fails at:
  • The board then resets and repeats the boot sequence.
  • The device can still be detected in recovery mode as an NVIDIA APX device.
  • I have not been able to successfully flash the device; the flashing process reports that the connected Jetson is not ready for flashing.
I would like to understand what 0xc1c00606 / reason: 0x06 / aux_info: 0x06 represents and, specifically, what could cause the MB1 → PSC mailbox communication to fail at this point in the boot process.
Is this indicative of a hardware problem with the PSC/SoC, or could this be caused by corrupted early-boot firmware/configuration?
I would appreciate any guidance on how to diagnose this further without erasing the existing eMMC data, if possible.
Thank you.
Please try to flash the latest version JetPack 6.2.3 or JetPack 7.2.1 to cross check.
Also provide the log if still failed.
