AGX Orin GPIO pulse when system boot up
Hi Nvidia,
We are using the AGX Orin and have configured pin 282 (L19, PEX_C6_CLKREQ_N) to Low via Pinmux.
However, during boot, we observe a brief High pulse on this pin.
This behavior seems very similar to the issue described in the following post:
In our case, however, we are not using a 3.3V level shifter.
The post appears to be from 2023, which would correspond to JetPack 5,
but we are currently encountering this issue on JetPack 6.2.
Have you received any similar reports or feedback since then?
For further guidance please refer to
in Jetson AGX Orin Series Design Guide at link below Log in | NVIDIA Developer
Hi sgursal,
However, I checked the MPIO Pad Code on Jetson_AGX_Orin_Series_Pin_Descriptions, L19 belongs to DD, not CZ.
Therefore, we could expect there is no glitch on this pin when power rail is enabled, right?
As you can see on L19 pin there is already a 47K pullup to 3V3 on the module (Jetson). This may pull the pin high initially before the pinmux is applied/configured.
