To access the pre-boot serial console on the Jetson AGX Orin via the Micro-B USB port, you don’t need to configure anything special in the UEFI settings. However, you do need to ensure that the USB serial console is enabled on the Jetson AGX Orin.
By default, the Jetson AGX Orin uses the USB-C port for USB device mode, and the Micro-B USB port is used for the serial console. To access the serial console, you’ll need to use a USB-TTL adapter, which converts the USB signal to a serial signal that can be read by a terminal emulator like GNU screen.
You don’t need an external Linux kernel driver on the Ubuntu host, as the USB serial console is a standard feature that is supported by most Linux distributions, including Ubuntu.
To access the serial console, follow these steps:
- Connect the Micro-B USB port on the Jetson AGX Orin to the Ubuntu host using a USB-TTL adapter.
- Open a terminal on the Ubuntu host and run the command
ls /dev/ttyUSB*
to find the device file associated with the USB serial console. This will typically be /dev/ttyUSB0
- Use GNU screen to connect to the serial console by running the command
screen /dev/ttyUSB0 115200
. This will open a terminal session with the serial console at a baud rate of 115200.
Note that you may need to adjust the baud rate depending on your specific setup.
In comparison to other Jetson modules, the Jetson AGX Orin has a similar setup for accessing the serial console. However, the Jetson Orin Nano uses a different setup, where the serial console is accessed through the USB-C port instead of the Micro-B USB port.
In terms of requirements, you’ll need to ensure that the Ubuntu host has the necessary dependencies installed, including screen
and usbutils
. You can install these packages using the command sudo apt install screen usbutils
Overall, accessing the pre-boot serial console on the Jetson AGX Orin via the Micro-B USB port requires a USB-TTL adapter and a terminal emulator like GNU screen. You don’t need to configure anything special in the UEFI settings or install external kernel drivers on the Ubuntu host.
