I have two Jetson AGX Orin boards connected together in this configuration:
Jetson AGX Orin (Host)
R34
USB A
V
Micro B
Jetson AGX Orin (Device)
R34
The host Orin recognizes the device Orin with dmesg --follow and lsusb.
The host Orin is also able to read/write to the device Orin’s serial UART debug console and see bootloader information.
I have a couple of questions:
With this configuration, is it possible to send serial data from the host to the device over USB-A to micro-B?
If so, how can I send serial data to the device and have the device read serial data?
If not, what other USB options can I use to send serial data from the host to the device?
The OTG port of Orin developer kit is the type-C port. Please use the type-A to type-C adapter to connect the two Orins. So that you can run the command on Orin host to login Orin device:
The host Orin dev kit does not recognize the other Orin when plugged in using the provided type-A to type-C cable (i.e. the device doesn’t show up on dmesg and lsusb), and so no ethernet-over-usb l4tbr0 interface with IP 192.168.55.1 is visible. Is the provided cable not a data cable?
