AGX Thor resets due to ESD when touching chassis
DRIVE OS Version: Ubuntu 24.04.4 LTS
Error String: -
Issue Description: Touch the AGX Thor case, device resets. I am in a carpeted environment. Does the AGX Thor not have chassis ESD protection?
Dear @crushfx ,
Are you using Jetson AGX Thor platform?
Hello, that is correct, I’m using the AGX Thor kit (purchased from Arrow) in its retail configuration, no modifications done to it, never opened. This doesn’t occur every time I touch it, but it has happened at least three times since purchased it about 6 months ago.
Moved to Jetson AGX thor forum
The Jetson Developer Kit has been tested for ESD per IEC 61000-4-2 standard.
However, please note that a carpeted environment is prone to generating significant static charges on the human body, especially in dry conditions. This is why labs and test environments typically do not use carpet flooring and instead use anti-static flooring to minimize ESD events.
