We are Normally Use Thor, And the system auto restart, below is the kernel log part:
2026-06-03T21:27:00.658646+08:00 localhost kernel: [RCE] right crop pixels=1280 bottom crop lines=960
2026-06-03T21:27:00.658650+08:00 localhost kernel: [RCE] pixel format=VI_PIXFMT_FORMAT_T_U8_Y8__V8_Y8 fmt=19
2026-06-03T21:27:00.946630+08:00 localhost kernel: obc_max96712 9-002d: check pipe lock: 0x00
2026-06-03T21:27:00.946658+08:00 localhost kernel: g300 9-0050: orb_setup_pipeline pipe lock: 0x0
2026-06-03T21:27:01.130705+08:00 localhost kernel: mcf_log_fault: 8 callbacks suppressed
2026-06-03T21:27:01.130730+08:00 localhost kernel: tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffffc00: EMEM address decode error (EMEM decode error)
2026-06-03T21:27:01.130732+08:00 localhost kernel: tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
2026-06-03T21:27:01.130741+08:00 localhost kernel: tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffffe00: EMEM address decode error (EMEM decode error)
2026-06-03T21:27:01.181032+08:00 localhost kernel: tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffff600: EMEM address decode error (EMEM decode error)
2026-06-03T21:27:01.181059+08:00 localhost kernel: tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffff400: EMEM address decode error (EMEM decode error)
2026-06-03T21:27:01.181061+08:00 localhost kernel: tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffffc00: EMEM address decode error (EMEM decode error)
2026-06-03T21:27:01.193985+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: EVTQ overflow detected -- events lost
2026-06-03T21:27:01.194008+08:00 localhost kernel: arm_smmu_evtq_thread: 81006 callbacks suppressed
2026-06-03T21:27:01.194011+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: event 0x10 received:
2026-06-03T21:27:01.194645+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000090000000010
2026-06-03T21:27:01.194667+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000020800000000
2026-06-03T21:27:01.194668+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000007ffe485c00
2026-06-03T21:27:01.194669+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000000000000000
2026-06-03T21:27:01.194670+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: event 0x10 received:
2026-06-03T21:27:01.194671+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000090000000010
2026-06-03T21:27:01.194684+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000020800000000
2026-06-03T21:27:01.194686+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000007ffe487c00
2026-06-03T21:27:01.194687+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000000000000000
2026-06-03T21:27:01.194688+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: event 0x10 received:
2026-06-03T21:27:01.194688+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000090000000010
2026-06-03T21:27:01.194689+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000020800000000
2026-06-03T21:27:01.194691+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000007ffe489c00
2026-06-03T21:27:01.194692+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000000000000000
2026-06-03T21:27:01.194693+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: event 0x10 received:
2026-06-03T21:27:01.194694+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000090000000010
2026-06-03T21:27:01.194695+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000020800000000
2026-06-03T21:27:01.194696+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000007ffe485d00
2026-06-03T21:27:01.194697+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000000000000000
2026-06-03T21:27:01.194698+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: event 0x10 received:
2026-06-03T21:27:01.194699+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000090000000010
2026-06-03T21:27:01.194700+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000020800000000
2026-06-03T21:27:01.194701+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000007ffe48dc00
2026-06-03T21:27:01.194702+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000000000000000
2026-06-03T21:27:01.194703+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: event 0x10 received:
2026-06-03T21:27:01.194712+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000090000000010
2026-06-03T21:27:01.194713+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000020800000000
2026-06-03T21:27:01.194713+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000007ffe48bc00
2026-06-03T21:27:01.194715+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000000000000000
2026-06-03T21:27:01.194715+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: event 0x10 received:
2026-06-03T21:27:01.194716+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000090000000010
2026-06-03T21:27:01.194717+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000020800000000
2026-06-03T21:27:01.194718+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000007ffe487d00
2026-06-03T21:27:01.194719+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000000000000000
2026-06-03T21:27:01.194720+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: event 0x10 received:
2026-06-03T21:27:01.194721+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000090000000010
2026-06-03T21:27:01.194722+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000020800000000
2026-06-03T21:27:01.194723+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000007ffe48fc00
2026-06-03T21:27:01.194724+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000000000000000
2026-06-03T21:27:01.194725+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: event 0x10 received:
2026-06-03T21:27:01.194726+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000090000000010
2026-06-03T21:27:01.194727+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000020800000000
2026-06-03T21:27:01.194728+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000007ffe491c00
2026-06-03T21:27:01.194728+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000000000000000
2026-06-03T21:27:01.194730+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: event 0x10 received:
2026-06-03T21:27:01.194730+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000090000000010
2026-06-03T21:27:01.194731+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000020800000000
2026-06-03T21:27:01.194732+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000007ffe489d00
2026-06-03T21:27:01.194733+08:00 localhost kernel: arm-smmu-v3 8806000000.iommu: 0x0000000000000000
2026-06-03T21:27:01.270635+08:00 localhost kernel: obc_max96712 9-002d: max96712_reset_oneshot oneshot reset all link.
2026-06-03T21:27:03.770636+08:00 localhost kernel: EtherCAT WARNING 0-2: Slave did not sync after 5000 ms.
2026-06-03T21:27:03.790629+08:00 localhost kernel: EtherCAT 0: Domain 0: Working counter changed to 6/18.
2026-06-03T21:27:09.442631+08:00 localhost kernel: EtherCAT WARNING 0-3: Slave did not sync after 5008 ms.
2026-06-03T21:27:09.462622+08:00 localhost kernel: EtherCAT 0: Domain 0: Working counter changed to 9/18.
2026-06-03T21:27:14.482493+08:00 localhost kernel: EtherCAT 0: Domain 0: Working counter changed to 12/18.
2026-06-03T21:27:15.160782+08:00 localhost kernel: EtherCAT 0: Slave states on main device: OP.
2026-06-03T21:27:15.490639+08:00 localhost kernel: EtherCAT 0: Domain 0: 3 working counter changes - now 18/18.
2026-06-03T21:29:51.230634+08:00 localhost kernel: _cmd_abort_notify(570)vv abort=1
