Hi
In the past time , i post a qusetion about how to set the i2c@c240000 as a slave mode, at https://forums.developer.nvidia.com/t/agx-xavier-how-to-set-the-i2c-c240000-as-a-i2c-slave-mode/189992
Now , i still meet some questions about setting the i2c@c240000 as a slave i2c node.
Please help , thank you
My setting steps like below:
1 : hardware\nvidia\platform\t19x\galen\kernel-dts\common\tegra194-p2888-0001-p2822-0000-common.dtsi
i add the code as below
i2c@c240000 {
compatible = "nvidia,tegra194-i2c-slave";
eeprom@64 {
reg = <0x64>;
compatible="slave-24c02";
status = "okay";
2 : make menuconfig
in kernel menuconfig, i set “Y” about some configs
Symbol: I2C_SLAVE [=y] │
│ Type : boolean │
│ Prompt: I2C slave support │
│ Location: │
│ -> Device Drivers │
│ -> I2C support │
│ (1) -> I2C support (I2C [=y]) │
│ Defined at drivers/i2c/Kconfig:112 │
│ Depends on: I2C [=y] │
│ Selected by: I2C_EMEV2 [=m] && I2C [=y] && HAS_IOMEM [=y] && HAVE_CLK [=y] || I2C_TEGRA_SLAVE [=y] && I2C [=y] && HAS_IOMEM [=y] && ARCH_TEGRA [=y] || I2C_RCAR [=n] && I2C [=y] && HAS_IOMEM [=y │
│ Symbol: I2C_SLAVE_EEPROM [=y] │
│ Type : tristate │
│ Prompt: I2C eeprom slave driver │
│ Location: │
│ -> I2C support │
│ -> I2C support (I2C [=y]) │
│ (2) -> I2C slave support (I2C_SLAVE [=y]) │
│ Defined at drivers/i2c/Kconfig:117 │
│ Depends on: I2C [=y] && I2C_SLAVE [=y] │
3 : dmesg | grep i2c
[ 0.794174] iommu: Adding device 3160000.i2c to group 13
[ 0.794647] iommu: Adding device c240000.i2c to group 14
[ 0.795051] iommu: Adding device 3180000.i2c to group 15
[ 0.795519] iommu: Adding device 3190000.i2c to group 16
[ 0.796097] iommu: Adding device 31b0000.i2c to group 17
[ 0.796525] iommu: Adding device 31c0000.i2c to group 18
[ 0.796986] iommu: Adding device c250000.i2c to group 19
[ 0.797396] iommu: Adding device 31e0000.i2c to group 20
[ 0.923203] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 7.259617] i2c /dev entries driver
[ 7.263784] i2c i2c-2: Added multiplexed i2c bus 30
[ 7.264095] i2c i2c-2: Added multiplexed i2c bus 31
[ 7.264396] i2c i2c-2: Added multiplexed i2c bus 32
[ 7.264623] i2c i2c-2: Added multiplexed i2c bus 33
[ 7.264778] i2c-slave-eeprom 1-0064: i2c_slave_register: client slave flag not set. You might see address collisions, flag = 0x0
[ 7.266107] tuyun-slave-eeprom_i2c: zp: func[i2c_slave_eeprom_probe] line[201]->|| chip_addr = 0x64
[ 7.266113] tuyun-slave-eeprom_i2c: zp: func[i2c_slave_eeprom_probe] line[202]->|| bin.size = 256
[ 11.123135] Error: Driver 'tegra194-i2cslv' is already registered, aborting...
4 : now i use two board , one board as i2c master, and one board as i2c slave, and use line connect two board
I use i2cdetect command to detect , but dont have any i2c slave address about the i2c slave
root@dev-desktop:~# i2cdetect -y -r -a 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
So i want to know where is wrong? And what should i do to realize the i2c slave mode.
Thank you very much!
