Please provide the following info: Hardware Platform: DRIVE AGX Xavier™ Developer Kit Software Version: DRIVE Software 10 Host Machine Version: native Ubuntu 18.04 SDK Manager Version: 1.2.0.6733
Hello everyone,
we suddenly having problems interacting with our Nvidia Drive AGX Xavier. We are using it now for about half a year and never really had a problem like that before:
When starting up the device, the fan starts working and everything seems normal. However, we don’t see a picture on the connected display, that is for both Xavier A and B.
Also, we cannot connect via ssh or minicom.
We just flashed it again with Drive OS 10, which seemed working, but that didn’t changed anything.
Is this a hardware error or is there anything else we can try?
Are you able to list out all the devices?
$ lsusb -d 0x0403:
Bus 001 Device 015: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 001 Device 014: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 001 Device 013: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 001 Device 012: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Could you also share your flash log (~/.nvsdkm/logs/DRIVE_Software_10.0_Linux_OS/NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP.log)? Thanks!
Yes, we tried connecting via minicom ttyUSB2/ttyUSB6 as described but with no success.
We can list out all devices:
$ lsusb -d 0x0403:
Bus 001 Device 010: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 001 Device 009: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 001 Device 008: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 001 Device 007: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
I didn’t find anything abnormal in your NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP.log.
Please provide the dmesg log around ttyUSB of your host system. It’s worth checking if there are any suspicious messages.
$ dmesg | grep ttyUSB
[ 53.154908] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB0
[ 53.157374] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB1
[ 53.158134] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB2
[ 53.158786] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB3
[ 53.159088] usb 1-1.5: FTDI USB Serial Device converter now attached to ttyUSB4
[ 53.159399] usb 1-1.5: FTDI USB Serial Device converter now attached to ttyUSB5
[ 53.164029] usb 1-1.5: FTDI USB Serial Device converter now attached to ttyUSB6
[ 53.164613] usb 1-1.5: FTDI USB Serial Device converter now attached to ttyUSB7
[ 53.165180] usb 1-1.6: FTDI USB Serial Device converter now attached to ttyUSB8
[ 53.165743] usb 1-1.6: FTDI USB Serial Device converter now attached to ttyUSB9
[ 53.166033] usb 1-1.6: FTDI USB Serial Device converter now attached to ttyUSB10
[ 53.166214] usb 1-1.6: FTDI USB Serial Device converter now attached to ttyUSB11
[ 53.166395] usb 1-1.7: FTDI USB Serial Device converter now attached to ttyUSB12
[ 53.166613] usb 1-1.7: FTDI USB Serial Device converter now attached to ttyUSB13
[ 53.166799] usb 1-1.7: FTDI USB Serial Device converter now attached to ttyUSB14
[ 53.166972] usb 1-1.7: FTDI USB Serial Device converter now attached to ttyUSB15
It turned out that minicom actually works! It was just that we got confused by the empty terminal output. You just have to press a random key to see something on the minicom shell.
The monitor still doesn’t detect any HDMI signal, however.
