Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”): Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Dear @maxandre.ogeret ,
Could you share lssub output after connecting debug USB cable?
Also, please share minicom connection settings for aurix port(Press CTRL A Z for help)
Bus 002 Device 002: ID 8087:8001 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8009 Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 04f2:b43b Chicony Electronics Co., Ltd
Bus 003 Device 002: ID 8087:0a2a Intel Corp.
Bus 003 Device 008: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 003 Device 007: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 003 Device 006: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 003 Device 005: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 003 Device 004: ID 0424:2807 Standard Microsystems Corp.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
And here’s the minicom config I am using :
port /dev/ttyUSB3
baudrate 115200
bits 8
parity N
stopbits 1
rtscts No
xonxoff No
It seems the board is connected as per lsusb. Could you check the below
Connect using sudo minicom -D /dev/ttyUSB3
Press CTRL A Z O
share screenshot of serial port connection details for confirmation
May I know, the condition of the board before you hit this issue? Is it on office desk or inside car? how it was used?
Did you check flashing latest release using sdkmanager?
The board spent most of this time on a desk for setting up the cameras and updating the firmware. We recently installed it in the car. And when testing the board with the official power supply once the board was installed in the car we had this problem. Nothing else than the power has been plugged, for testing purposes.
It seems that it stopped working without any obvious reasons, the board has been handled according to the documentation without exception.
We managed to find the problem.
The MCU programming switch has been switched to PRG inadvertently. It’s very sad that there is no notification from the debug TTYs.
Everything is working fine now.
