hi,
I would like to use PCIe SRNS on AGX Xavier, I followed these steps:
- Go to your Linux_for_Tegra folder.
- Search the dtb tegra194-a02-bpmp-p2888-a04.dtb.
- Use dtc tool to convert this dtb back to dts
- Add the patch to the dts
- Use dtc tool to convert the dts back to dtb
- Flash the board and see if it can work.
add this node in Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb:
clock@plle {
clk-id = <0x64>;
pll_freq_table = <0x249f000 0x5f5e100 0x2 0x7d 0x18 0xffffffff 0xffffffff 0xffffffff 0xffffffff>;
But the system cannot successfully bootup when I connect to NVMe on [J6] PCIe x16 connector (routes to a x8 PCIe 4.0 controller).
my question is does AGX Xavier support a separate reference clock or not? or does it support SRNS?
