Hello ~
We are trying to use USB C connector without PD controller in AGX Xavier.
I would like to refer to the recovery port part of the Orin P3768_A04 circuit diagram. There will be no problem, right?
Hello ~
We know this is ORIN NX DG, but we referenced it for simplicity. Please confirm.
It should be fine, but is not validated on Xavier. And it should be USB0_DP/DN for recovery.
For simple data communication, I used USB1 port. Thank you for answer.
