On a fresh Windows 11 with missing $USER\.ssh folder Workbench fails to install:
I would check to see if the $USER/.ssh folder exists. I’m not sure if NV Sync creates it by itself if the folder does not exist
The fix is trivial. However, the Workbench installer shouldn’t fail and instead create the .ssh folder if not present.
This is an issue with NV Sync. Thank you for bringing this to our attention, I will see if this is something we can add in a future release
