fail this command:
Command failed: wsl -u workbench -d NVIDIA-Workbench – /home/workbench/.nvwb/bin/wb-svc -gid 1000 -uid 1000 check-host
panic: runtime error: index out of range [-1]
follow the full log:
[2024-02-22 00:19:36.104] [info] (tray) initTray
[2024-02-22 00:19:36.107] [info] (main) NVWB_CLI_VERSION 0.13.14 WB_SVC_VERSION 0.18.7 CREDENTIAL_MANAGER_VERSION 1.1.1
[2024-02-22 00:19:36.109] [info] (tab-registry) cleared project-tag-registry store
[2024-02-22 00:19:36.122] [info] (window-context-registry) cleared window-context-registry-store
[2024-02-22 00:19:36.130] [info] (main) async() Start electron main
[2024-02-22 00:19:36.180] [info] (menu) initMenu
[2024-02-22 00:19:36.182] [info] (main) message with user scope
[2024-02-22 00:19:36.183] [info] (createWindow-installer)
createWindow(
windowName: installer,
windowIndex: ./installer/index.html,
options {“width”:952,“height”:650},
[2024-02-22 00:19:36.210] [info] (createWindow-installer) resetToDefaults(windowState: [object Object])
[2024-02-22 00:19:36.210] [info] (createWindow-installer) windowWithinBounds()
[2024-02-22 00:19:36.247] [info] (new-window-events) event { preventDefault: ‘[function] preventDefault(){}’ }
[2024-02-22 00:19:36.248] [info] (new-window-events) data {
setBounds: ‘[function] (e,…t)=>{e={…this.getBounds(),…e},s.call(this,e,…t)}’,
_events: {
blur: ‘[function] t=>{e.emit(“browser-window-blur”,t,this)}’,
focus: ‘[function] t=>{e.emit(“browser-window-focus”,t,this)}’,
show: ‘[function] ()=>{const e=this.isVisible()&&!this.isMinimized();if(i!==e){i=e;const t=i?“visible”:“hidden”;this.webContents.emit(“-window-visibility-change”,t)}}’,
hide: ‘[function] ()=>{const e=this.isVisible()&&!this.isMinimized();if(i!==e){i=e;const t=i?“visible”:“hidden”;this.webContents.emit(“-window-visibility-change”,t)}}’,
minimize: ‘[function] ()=>{const e=this.isVisible()&&!this.isMinimized();if(i!==e){i=e;const t=i?“visible”:“hidden”;this.webContents.emit(“-window-visibility-change”,t)}}’,
maximize: ‘[function] ()=>{const e=this.isVisible()&&!this.isMinimized();if(i!==e){i=e;const t=i?“visible”:“hidden”;this.webContents.emit(“-window-visibility-change”,t)}}’,
restore: ‘[function] ()=>{const e=this.isVisible()&&!this.isMinimized();if(i!==e){i=e;const t=i?“visible”:“hidden”;this.webContents.emit(“-window-visibility-change”,t)}}’
_eventsCount: 7
[2024-02-22 00:19:36.277] [info] (channel-registry) registerIpcChannels() Register ipc channels
[2024-02-22 00:19:36.278] [info] (open-workbench) open_window
[2024-02-22 00:19:36.279] [info] (open-file-picker-channel) open_file_picker
[2024-02-22 00:19:36.279] [info] (project-tab-registry-channel) project_tab_registry_channel
[2024-02-22 00:19:36.279] [info] (open-file-picker-channel) open-external-link
[2024-02-22 00:19:36.280] [info] (open-file-picker-channel) open_file
[2024-02-22 00:19:36.280] [info] (open-folder-picker-channel) open_folder
[2024-02-22 00:19:36.281] [info] (renderer) electron-log
[2024-02-22 00:19:36.281] [info] (open-in-context-channel) open_project_in_context
[2024-02-22 00:19:36.892] [info] (renderer) Installer App() Loading
[2024-02-22 00:19:36.938] [info] (renderer) Navigating to transition, /
[2024-02-22 00:19:36.940] [info] (renderer) SERVICE: workbenchServiceInstalledCheck(), CHANNEL: [get_storage, service_install_check]
[2024-02-22 00:19:36.940] [info] (get-app-storage) {
_deserialize: ‘[function] e=>JSON.parse(e)’,
_serialize: ‘[function] e=>JSON.stringify(e,void 0,“\t”)’,
events: { _events: {}, _eventsCount: 0 },
path: ‘C:\Users\simof\AppData\Local\NVIDIA Corporation\AI Workbench\registries\workbench-config.json’
} installer.workbenchServiceState
[2024-02-22 00:19:36.941] [info] (get-app-storage) {
firstLoad: true,
isInstalled: false,
remoteOnly: null,
rebootFromWSL2: true,
installationHasRunSuccessfully: false
[2024-02-22 00:19:36.943] [info] (service-installed-check-channel) ServiceInstalledCheck.handle()
[2024-02-22 00:19:36.943] [info] (service-installed-check) serviceInstalledCheck()
[2024-02-22 00:19:36.950] [info] (renderer) Navigating to transition, /
[2024-02-22 00:19:39.455] [info] (service-installed-check) wsl -u workbench -d NVIDIA-Workbench – ls /home/workbench/.nvwb/bin/ nvwb-cli
wb-svc
[2024-02-22 00:19:40.434] [info] (service-utilities) {
stdout: ‘\n’ +
’ nvwb 0.13.14 (stable; linux; amd64; go1.21.3; Wed Jan 10 20:09:13 UTC 2024) \n’ +
‘\n’,
stderr: ‘’
} 0.13.14
[2024-02-22 00:19:40.435] [error] (service-utilities) ensureLatest: stdout
[2024-02-22 00:19:40.750] [info] (service-utilities) {
stdout: ‘wb-svc 0.18.7 (stable; linux; amd64; go1.21.3; Wed Jan 10 20:04:19 UTC 2024)\n’,
stderr: ‘’
} 0.18.7
[2024-02-22 00:19:40.750] [error] (service-utilities) ensureLatest: stdout wb-svc 0.18.7 (stable; linux; amd64; go1.21.3; Wed Jan 10 20:04:19 UTC 2024)
[2024-02-22 00:19:40.932] [info] (service-installed-check) credentialManagerPathCheck bin
cli.yaml
logs
true
[2024-02-22 00:19:40.933] [info] (check-if-exists) “C:\Users\simof\AppData\Local\NVIDIA Corporation\AI Workbench\credential-manager.exe”
[2024-02-22 00:19:40.934] [error] (check-if-exists) checkIfExists ENOENT: no such file or directory, access ‘C:\Program Files\NVIDIA AI Workbench"C:\Users\simof\AppData\Local\NVIDIA Corporation\AI Workbench\credential-manager.exe"’
[2024-02-22 00:19:40.934] [info] (service-installed-check) isCredentialManagerInstalled false
[2024-02-22 00:19:40.993] [info] (service-utilities) {
stdout: ‘credential-manager 1.1.1 (stable; windows; amd64; go1.21.3; Tue Jan 2 22:49:32 UTC 2024)\n’,
stderr: ‘’
} 1.1.1
[2024-02-22 00:19:40.993] [error] (service-utilities) ensureLatest: stdout credential-manager 1.1.1 (stable; windows; amd64; go1.21.3; Tue Jan 2 22:49:32 UTC 2024)
[2024-02-22 00:19:41.173] [info] (service-installed-check) credential_manager.path true /mnt/c/Users/simof/AppData/Local/NVIDIA Corporation/AI Workbench/credential-manager.exe /mnt/c/Users/simof/AppData/Local/NVIDIA Corporation/AI Workbench/credential-manager.exe
[2024-02-22 00:19:41.174] [info] (service-installed-check) serviceInstalledCheck(): isWBInstalled = true
[2024-02-22 00:19:41.175] [info] (service-installed-check) serviceInstalledCheck(): isCLIInstalled = true
[2024-02-22 00:19:41.175] [info] (service-installed-check) serviceInstalledCheck(): isCredentialInstalled = true
[2024-02-22 00:19:41.175] [info] (service-installed-check-channel) {
workbench: {
isInstalled: true,
location: ‘\\wsl.localhost\NVIDIA-Workbench\home\workbench\.nvwb\bin\wb-svc’
cli: {
isInstalled: true,
location: ‘\\wsl.localhost\NVIDIA-Workbench\home\workbench\.nvwb\bin\nvwb-cli’
credentialManager: {
isInstalled: true,
location: ‘“C:\Users\simof\AppData\Local\NVIDIA Corporation\AI Workbench\credential-manager.exe”’
[2024-02-22 00:19:41.178] [info] (check-host-channel) check_host
[2024-02-22 00:19:41.178] [info] (check-host) checkHost()
[2024-02-22 00:19:43.703] [error] (check-host) Command failed: wsl -u workbench -d NVIDIA-Workbench – /home/workbench/.nvwb/bin/wb-svc -gid 1000 -uid 1000 check-host
goroutine 1 [running]:
gitlab-master.nvidia.com/workbench/workbench-service/pkg/introspect.getHostInfo()
/builds/workbench/workbench-service/pkg/introspect/host.go:254 +0xddc
gitlab-master.nvidia.com/workbench/workbench-service/pkg/introspect.InitHostState({0x34630b8a000?, 0x0?}, 0x0?, 0x0?)
/builds/workbench/workbench-service/pkg/introspect/host.go:312 +0x65
main.main()
/builds/workbench/workbench-service/main.go:204 +0x1326
[2024-02-22 00:19:43.704] [info] (renderer) SERVICE: hostCheck(), CHANNEL: check_host
[2024-02-22 00:19:43.705] [error] (renderer) error.platform.installer.get_initial_state:invocation[0] {
type: ‘app_error’,
data: { message: ‘Something went wrong please restart your installer’ }
[2024-02-22 00:19:43.705] [info] (renderer) Navigating to app-error, /transition
