If you are reporting a bug or error, consider submitting a Support Bundle to aiworkbench-ea@nvidia.com. This will help us solve your issue more quickly.
Please describe your issue or request: (tick the boxes after creating this topic):
main.log (24.9 KB)
Stuck at this step (been here for about an hour doing nothing, no apparent CPU/network usage from it either) so appears stuck. -
Closing it and reopening it after each of these steps
Restarting after any uninstalling/installing
Uninstalled NVIDIA AI workbench, then reinstalling from up to date installer (done after any step where i
Installed, uninstalled
Manually installed docker myself to remove dependency
Removed password requirement for workbench user in WSL after noticing password failures in log. Didn’t seem to do anything so did a clean reinstall after.
Uninstalling and reinstalling WSL
Disabling firewall to ensure nothing is blocking port 500001
Removing the requirement for admin permissions to edit anything.
Changed from wifi to ethernet to ensure stable connection
Disabled and reenabled Hypervirtualisation.
Progress made - Core packages check has disappeared, so its just getting stuck on gitLFS.
System info
Intel Core 19-14900KF
NVIDIA GeForce RTX 4090
64gb DDR5 RAM
Like 3tb of spare space.
Please tick the appropriate box to help us categorize your post
Bug or Error
Feature Request
Documentation Issue
Other
