ALSA lib pcm_dmix.c:1089:(snd_pcm_dmix_open) unable to open slave
Hello, I have similar problem as topic, but there is no solution.
Full log:
ALSA lib pcm_dsnoop.c:641:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.USB-Audio.pcm.hdmi.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib conf.c:4732:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5220:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM hdmi
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
ALSA lib pcm_dmix.c:1024:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
When I do: cat /proc/asound/cards:
0 [U0x46d0x825    ]: USB-Audio - USB Device 0x46d:0x825
                      USB Device 0x46d:0x825 at usb-3610000.xhci-4.4, high speed
 1 [HDA            ]: tegra-hda - NVIDIA Jetson AGX Orin HDA
                      NVIDIA Jetson AGX Orin HDA at 0x3518000 irq 117
 2 [APE            ]: tegra-ape - NVIDIA Jetson AGX Orin APE
                      Unknown-JetsonAGXOrin-NotSpecified
 3 [Device         ]: USB-Audio - USB Audio Device
                      C-Media Electronics Inc. USB Audio Device at usb-3610000.xhci-4.3, full speed
In /usr/share/alsa/alsa.conf my default card and device are set to 0.
When I test my microphone in Ubuntu GUI or web app it works, but in my python program it doesn’t. I am using SpreechRecognition package and my sound capture line looks like this:
with sr.Microphone() as source:
so by default it should pick device 0 and card 0
Anybody know where is the problem?
Can you try below commands to set default sound devices.
pacmd list-sinks for name or index number of possible sinks
pacmd list-sources for name or index number of possible sources
pacmd set-default-sink "SINKNAME" | index to set the default output sink
pacmd set-default-source "SOURCENAME" | index to set the default input
