Hello!
I need to connect three FPGAs to a Jetson AGX Orin, please consider the Industrial Module. The Jetson specification defines a compatibility with “Up to 2 x8 + 1 x4 + 2 x1”. So, theoretically we have 6 PCIe controllers, right? However, the design guide describes the supported configuration, and I didn’t understand if those are the all supported configurations.
For example, I would like to connect TWO x4 PCIe devices to UPHY1 interface (Compatible with 1 x8), and ONE x4 to UHPY0, is it possible?
There is a similar topic (Splitting PCIe x8 into 8 times x1), and the answer was “There are no 8 pcie controllers”, but in my case, I would use only 3 controllers.
If I can’t “split” a x8 into two x4, I would be able to use the x8 as x4 only, and ignore the other lanes?
