Tried to use flash.sh tool to update my TX2 (by using the standard command “./flash.sh -r jetson-tx2-devkit mmcblk0p1”, i have created by system.img] but encountered an error message below. Would like to have your advice how to proceed. thank you.
Have you modified the flash content in any other way? Which L4T release version is it?
I have no idea if this is related, but what is the exact byte size of the system.img file you created? It should be an integer multiple of either MiB (1024*1024) or GiB (1024*1024*1024). The “size” parameter to flash.sh could be used in case it is an issue of a non-default size. As an example, if the file is 16106127360 bytes (15 * 1024 * 1024 * 1024), then it is 15GiB, and you might use: sudo ./flash.sh -r -S 15GiB jetson-tx2-devkit mmcblk0p1
(note that I’m also including the “-r” so it reuses your image)
