SDKM_logs_JetPack_4.6.4_Linux_for_Jetson_TX2_modules_2024-04-11_11-20-58.zip (43.3 KB)
I don’t really know what’s the error here.
Ref : Quick Start — Jetson Linux<br/>Developer Guide 34.1 documentation
Flashing TX2 OS by manual…
What’s the error?
You are using TX2 and you are referring to documents of 34.1?
Are you sure what you are doing?
Most of the operations don’t need to be changed; only this part below needs modification.
sudo ./flash.sh jetson-tx2 mmcblk0p1
So what’s the error now?
Everything is OK now.
