I’m trying to flash my tx2 but keep getting the following error. Can you walk me through how to fix it. The flash gets all the way to 99.8% and then fails. Please provide step by step instructions on how to resolve this issue.
18:58:23 INFO : Flash Jetson TX2 : Error: Return value 3
18:58:23 INFO : Flash Jetson TX2 : Command tegradevflash_v2 --pt flash.xml.bin --create
18:58:23 INFO : Flash Jetson TX2 : Failed flashing t186ref.
18:58:23 INFO : Flash Jetson TX2 : exit status 1
18:58:23 INFO : Flash Jetson TX2 : [ Component Install Finished with Error ]
18:58:23 INFO : Flash Jetson TX2 : [ 7.38 MB used. Disk Avail: 390.17 GB ]
18:58:23 INFO : Flash Jetson TX2 : [ NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP Install took 10m48s ]
18:58:23 ERROR : Flash Jetson TX2 : Run commands failed at step Install: command sudo ./flash.sh jetson-tx2 mmcblk0p1 finished with error
18:58:23 ERROR : Flash Jetson TX2 : command terminated with error
