Host System:18.04 Ubuntu
Traget System :jetson tx2
installation through jetpack 4.6.2
installation breaks inbetween installation
for a detail report i am sharing you the log
what to do now to get out of this
TS to /media/ubuntu/OldUbuntu/TX2/TargeHW/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/rootfs/
14:13:11 INFO: File System and OS - target_image: exec_command: /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP.sh
14:15:39 : File System and OS - target_image: WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
14:15:39 INFO: File System and OS - target_image: Get:12
file:/var/visionworks-tracking-repo Release [2,008 B]
14:15:39 INFO: File System and OS - target_image: Hit:17
14:15:39 INFO: File System and OS - target_image: Hit:19
14:15:40 INFO: File System and OS - target_image: Hit:20
14:15:40 INFO: File System and OS - target_image: Hit:21
14:15:41 INFO: File System and OS - target_image: Reading package lists…
14:15:41 INFO: File System and OS - target_image: Building dependency tree…
14:15:41 INFO: File System and OS - target_image: Reading state information…
14:15:41 INFO: File System and OS - target_image: All packages are up to date.
14:15:41 : File System and OS - target_image: WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
14:15:42 INFO: File System and OS - target_image: Building dependency tree…
14:15:42 INFO: File System and OS - target_image: Reading state information…
14:15:42 INFO: File System and OS - target_image: The following packages were automatically installed and are no longer required:
14:15:42 INFO: File System and OS - target_image: Use ‘sudo apt autoremove’ to remove them.
14:15:42 INFO: File System and OS - target_image: 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
14:15:42 INFO: File System and OS - target_image: Using rootfs directory of: /media/ubuntu/OldUbuntu/TX2/TargeHW/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/rootfs
14:15:42 ERROR: File System and OS - target_image: command terminated with error
14:15:42 SUMMARY: Flash Jetson TX2 - flash: Depends on failed component
