Trying to flash Jetson OS using Jetpack SDK on Ubuntu 18.04. Every time I get ERROR: File System and OS: command terminated with error. The full log is given below:
22:01:41 INFO: File System and OS: verifying checksum of /media/hasnain/Installations/jetson/download/Tegra_Linux_Sample-Root-Filesystem_R32.5.0_aarch64.tbz2
22:01:43 INFO: File System and OS: Found file /media/hasnain/Installations/jetson/download/Tegra_Linux_Sample-Root-Filesystem_R32.5.0_aarch64.tbz2 with correct checksum, skip downloading.
22:01:43 DEBUG: running command < true >
22:01:43 INFO: command finished successfully
22:01:43 DEBUG: File System and OS: using adapter to install NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP@JETSON_AGX_XAVIER to /media/hasnain/Installations/jetson/nvidia_sdk/JetPack_4.5_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs/
22:01:43 INFO: File System and OS: [host] [ Disk Avail:28.52 GB ]
22:01:43 INFO: File System and OS: exec_command: /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP.sh
22:01:43 INFO: File System and OS: [host] [sudo] password for hasnain:
22:01:43 INFO: File System and OS: *begin sudo apt-get install -y qemu-user-static , 5
22:01:44 INFO: File System and OS: Reading package lists...
22:01:44 INFO: File System and OS: Building dependency tree...
22:01:44 INFO: File System and OS: Reading state information...
22:01:44 INFO: File System and OS: 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
22:01:44 INFO: File System and OS: *begin sudo apt-get install -y python , 5
22:01:45 INFO: File System and OS: Building dependency tree...
22:01:45 INFO: File System and OS: Reading state information...
22:01:45 INFO: File System and OS: 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
22:01:45 INFO: File System and OS: exec_command: /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP.sh
22:05:48 INFO: File System and OS: Using rootfs directory of: /media/hasnain/Installations/jetson/nvidia_sdk/JetPack_4.5_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs
22:05:48 ERROR: File System and OS: command terminated with error
22:05:48 SUMMARY: Flash Jetson AGX Xavier 16GB/32GB: Depends on failed component
INSTALLATION FAILED
Please review the terminal tab for details. Resolve and RETRY.
