Jetson agx
sdkmanager 1.9.3
jetpack5.1.1
jetson AGX xavier kit
When I use sdkmanager to burn Jetpack 5.1.1. Prompt for the following error
15:44:01 INFO: File System and OS - target_image: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 7EA0A9C3F273FCD8
15:44:04 INFO: File System and OS - target_image: Reading package lists…
15:44:04 ERROR: File System and OS - target_image: E: The repository ‘Index of linux/ubuntu/ focal InRelease’ is not signed.
15:44:04 INFO: File System and OS - target_image: Building dependency tree…
15:44:04 INFO: File System and OS - target_image: Reading state information…
15:44:04 INFO: File System and OS - target_image: 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
15:44:04 INFO: File System and OS - target_image: Using rootfs directory of: /home/wangxin/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/rootfs
15:44:04 INFO: File System and OS - target_image: Installing extlinux.conf into /boot/extlinux in target rootfs
15:44:04 INFO: File System and OS - target_image: /home/wangxin/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/nv_tegra/nv-apply-debs.sh
15:44:04 INFO: File System and OS - target_image: Copying public debian packages to rootfs
15:44:04 INFO: File System and OS - target_image: Skipping installation of nvidia-l4t-dgpu-apt-source_35.3.1-20230319081403_arm64.deb …
15:44:04 INFO: File System and OS - target_image: Skipping installation of nvidia-l4t-dgpu-config_35.3.1-20230319081403_arm64.deb …
15:44:05 INFO: File System and OS - target_image: ERROR qemu not found! To install - please run: “sudo apt-get install qemu-user-static”
15:44:05 ERROR: File System and OS - target_image: command terminated with error
15:44:05 SUMMARY: Flash Jetson Linux - flash: Depends on failed component
sdkm-2023-08-01-15-49-07.log (126.7 KB)
It looks like this topic was posted to the wrong category. I am moving it to the Jetson section for visibility.
Are you using VM or with a native Ubuntu 20.04 host PC to install the SDK manager?
I think you should just follow what this line tells you…
run
on your host and try again
I have solved it. After countless attempts to delete the cache file, thank you
