Jetson TX2 os install
hello.
I tried to install L4T r32.1 on Jetson TX2 8GB.
The installation failed.
I proceeded with the installation in the following order.
  1. download ‘JAX-TX2-Jetson_Linux_R32.1.0_aarch64.tbz2’ and ‘JAX-TX2-Tegra_Linux_Sample-Root-Filesystem_R32.1.0_aarch64.tbz2’.
  2. Recovery mode of TX2 module
  3. Enter command in terminal of host pc.
    sudo tar xpf JAX-TX2-Jetson_Linux_R32.1.0_aarch64.tbz2
    cd Linux_for_Tegra/rootfs/
    sudo tar xpf …/…/JAX-TX2-Tegra_Linux_Sample-Root-Filesystem_R32.1.0_aarch64.tbz2
    cd …
    sudo ./apply_binaries.sh
    sudo ./flash.sh jetson-tx2 mmcblk0p1
The ‘flash.sh’ hangs under the following circumstances.
What’s the problem?
[   8.1290 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[   8.1299 ]
[   8.1306 ] tegrahost_v2 --chip 0x18 --generateblob blob.xml blob.bin
[   8.1312 ] number of images in blob are 9
[   8.1313 ] blobsize is 4097256
[   8.1314 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 203312
[   8.1327 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 89360
[   8.1330 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 63104
[   8.1333 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2082144
[   8.1339 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 533904
[   8.1342 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt of size 466240
[   8.1348 ] Added binary blob_tos-trusty_sigheader.img.encrypt of size 313152
[   8.1351 ] Added binary blob_eks_sigheader.img.encrypt of size 1440
[   8.1354 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt of size 344448
[   8.1363 ]
[   8.1364 ] Sending bootloader and pre-requisite binaries
[   8.1370 ] tegrarcm_v2 --download blob blob.bin
[   8.1376 ] Applet version 01.00.0000
[   8.3894 ] Sending blob
[   8.3897 ] [................................................] 100%
[   8.8561 ]
[   8.8592 ] tegrarcm_v2 --boot recovery
[   8.8604 ] Applet version 01.00.0000
[   9.1137 ]
[  10.1179 ] tegrarcm_v2 --isapplet
[  10.7960 ]
[  11.0021 ] tegradevflash_v2 --iscpubl
Hi @mk.kang ,
I couldn’t find the “jetson-tx2” parameter on the documentation. If your module is tx2 developer kit, the flash command must be like below.
I am not sure that it will work or not but you can try following command.
sudo ./flash.sh jetson-tx2-devkit mmcblk0p1
Regards.
I found documentation of nvidia(PCN 206440) related to this issue.
Jetson TX2 modules produced from July 7, 2020 can only be installed with jetson 4.4(L4T r32.4.3) or higher version. But I tried to install jetpack 4.2. So it didn’t install.
Is there any way to install jetpack 4.2 version in new modules?
No, please use the version that we suggested.
