AODT RAN DT: Recommended implementation path for adding 10/20/40 MHz support
Hi Aerial team,
We are interested in extending AODT RAN DT to support 10/20/40 MHz, instead of the current fixed 100 MHz configuration.
Could you please advise which modules would need to be modified for this?
Any guidance would be appreciated.
Many thanks,
Quan
Hi @quan.pham_van
AODT uses Aerial Cuda Accelerated RAN (ACAR) code for RAN simulations, and ACAR currently supports 30 MHz, 40 MHz, 50 MHz, 80 MHz channel BWs beside 100MHz.
10 MHz and 20 MHz channels BWs are not supported yet.
Thank you.
