Inquiry on Compatibility and Performance Impact of Running AODT on RTX 40 Series GPUs
Hello, I currently only have an RTX 40 series GPU for frontend and would like to try running AODT. Is this possible?
If it is possible, to what extent can it be done? How much performance degradation should I expect?
@user156103 i am just another user but haven’t tried to use AODT. that said, cards like the 40 series should be able to run AODT; but, i can’t say with certainty the bottleneck you might see in performance. there was another thread recently that asked about frontend hardware suggestions which may offer some additional insight. other than that, i’d have to defer to the devs/mods to provide some benchmark.
We do not support AODT here I am sorry.
You need to post here at https://forums.developer.nvidia.com/c/accelerated-computing/aerial/674. You need to sign up for the 6G developer program BEFORE you can access the forum. Sign up at 6G Developer Program | NVIDIA Developer and then go to https://forums.developer.nvidia.com/c/accelerated-computing/aerial/674
