Questions on AODT GPU requirement
Hi, I have several questions regarding AODT installation.
For frontend GPU requirement, the installation guide above indicates GTX/RTX in “GPU requirement” column.
Does this mean any GTX or RTX GPU can be used for frontend, assuming GPU vRAM requirement is met?
But, the “GPU notes” columns lists RTX 6000 Ada, A10, and L40 as examples, among which I think that A10 and L40 are not GTX/RTX series. Are those GPUs (i.e. RTX 6000 Ada, A10, and L40) recommended list even though any GTX/RTX is supported for frontend?
Can I use V100, A100, H100, L4, or L40S for frontend GPU?
It would be very helpful if I could get more detailed guide/information for frontend GPU requirements.
In general, you’d probably want cards that have RT cores. below are some of the inquiries in the past and answers from the devs/mods for you to reference (not AODT specific, but should be applicable to OV kit-based applications):
You should stick to A6000s and L40s ideally
