The Installation process gets an “Application Error” and says to restart the application or reinstall. if it persists to contact support.
I re-run the application, it runs and open up to Environment Selection with options to select a local environment or connect to remote.
When i click the Local environment i get an error that tells me to look at nvwb logs.
The nvwb logs says “credential-manager.exe: no such file or directory”
The path its trying to access is wrong. the logs show
“/mnt/c/Users/badeed/AppData/Local/NVIDIA Corporation/AI Workbench/credential-manager.exe”
but the correct path is
“/mnt/c/Users/badee/AppData/Local/NVIDIA Corporation/AI Workbench/credential-manager.exe”
My windows username is “badeed” but my folder is “badee”
{“level”:“error”,“error”:“fork/exec /mnt/c/Users/thisisjaymehta/AppData/Local/NVIDIA Corporation/AI Workbench/credential-manager.exe: no such file or directory”,“isWrapped”:false,“isInteractive”:false,“engine”:“json”,“detail”:“detail”,“time”:“2024-06-09T16:20:51+05:30”,“message”:“Could not populate 3rd party credentials in the Workbench Service”}
This is wrong path. Correct path should be /mnt/c/Users/jayme/AppData/Local/NVIDIA Corporation/AI Workbench/credential-manager.exe
No, Windows set up on windows 11 only allows 5 character folder names if made using Microsoft Account.
So my set up email was badeed@domain.com
The folder became “badee” the User still is “badeed”
It’s a Windows set up thing/issue. Which is extremely annoying. I spent long time trying to making 6 characters by default all workarounds had some sort of flaw/issue. So I gave up.
