Applying Text To Surface Results in only grey image
I’ve been having a difficult time getting a .png file to appear as a texture on a cube using code. The cube appears as uniform grey. If I do the same thing via the UI, it works just fine. I’ve also walked through all the parameters in the Isaac Sim UI and compared the code generated ones to the UI generated one and I don’t see any differences. I’d greatly appreciate any pointers to what I’m doing wrong. Thank you!
Here are a couple of the approaches I’ve tried:
(1)
    # Create a new stage
    # Headsup display path
    display_path = Sdf.Path("/World/HeadsupDisplay")
    # Define the path for the cuboid
    cuboid_path = display_path.AppendPath("VisualCuboid")
    # Create a cuboid with unequal sides
    cuboid = UsdGeom.Cube.Define(stage, cuboid_path)
    cuboid.GetSizeAttr().Set(1)  # This is a placeholder, we'll scale it to make it a cuboid
    # Scale the cuboid to make it a VisualCuboid
    xform = UsdGeom.XformCommonAPI(cuboid)
    xform.SetScale((0.2, 0.1, 0.3))  # Set the scale to make it a cuboid with unequal sides
    # Create a material
    material_path = display_path.AppendPath("Material")
    material = UsdShade.Material.Define(stage, material_path)
    # Create a shader
    shader = UsdShade.Shader.Define(stage, material_path.AppendChild("Shader"))
    shader.CreateIdAttr("UsdPreviewSurface")
    # Set the texture file
    texture = UsdShade.Shader.Define(stage, material_path.AppendChild("Texture"))
    texture.CreateIdAttr("UsdUVTexture")
    texture.CreateInput("file", Sdf.ValueTypeNames.Asset).Set(Sdf.AssetPath(image_path))
And (2)
        headsup_prim_path = f"{prim_path}/headsup_display"
        omni.kit.commands.execute(
            "CreateMeshPrimWithDefaultXform",
            prim_type="Cube",
            prim_path=headsup_prim_path,
            select_new_prim=True,
            prepend_default_prim=True,
            above_ground=True,
        material_prim_path = f"{headsup_prim_path}/Looks/PreviewSurfaceTexture"
            "CreatePreviewSurfaceTextureMaterialPrim",
            mtl_path=material_prim_path,
        preview_surface_texture_material = PreviewSurface(
            prim_path=material_prim_path,
        diffuse_color_texture_shader_prim = get_current_stage().GetPrimAtPath(
            f"{material_prim_path}/diffuseColorTex"
        if not diffuse_color_texture_shader_prim:
            omni.log.warn(f"Shader not found! {material_prim_path}/diffuseColorTex")
            return
        # Ensure the diffuse_color_texture is a UsdShade.Shader
        diffuse_color_texture_shader = UsdShade.Shader(diffuse_color_texture_shader_prim)
        if not diffuse_color_texture_shader:
            raise ValueError(
                f"Prim at path {diffuse_color_texture_shader_prim.GetPrimPath()} is not a UsdShade.Shader"
        file_input = diffuse_color_texture_shader.GetInput("file")
        if file_input is not None:
            texture_asset = Sdf.AssetPath(image_path)
            file_input.Set(texture_asset)
        # Scale Mesh Cube
        headsup_prim = RigidPrim(
            translation=[0.0, 0.0, 0.02458],
            scale=[0.5, 0.01, 0.5],
            orientation=euler_angles_to_quat([0, 0, 0], degrees=True, extrinsic=False),
        headsup_prim.disable_rigid_body_physics()
        geometry_prim = GeometryPrim(prim_path=headsup_prim_path)
        geometry_prim.set_collision_enabled(True)
        # Bind the material to the prim
        material_api = UsdShade.MaterialBindingAPI(headsup_prim.prim)
        material_api.Bind(preview_surface_texture_material.material)
Doing everything with omni.kit.commands works:
cls.headsup_prim_path = f"{CELL_PRIM_PATH}/headsup_display"
# Create the headsup display surface
result, cube_prim_path = omni.kit.commands.execute(
    "CreateMeshPrim",
    prim_type="Cube",
    prim_path=f"{cls.headsup_prim_path}/Cube",
    object_orgin=Gf.Vec3f(0.0, 0.0, 0.0),
if not result:
    raise ValueError(f"Failed to create Cube prim at path: {cls.headsup_prim_path}/Cube")
# Create the material
result, _ = omni.kit.commands.execute(
    mtl_path=f"{cls.headsup_prim_path}/looks/default_visual_material",
if not result:
    raise ValueError(
        f"Failed to create material at path: {cls.headsup_prim_path}/looks/default_visual_material"
# Bind the material to the cube
    "BindMaterial",
    prim_path=cls.headsup_prim_path,
    material_path=f"{cls.headsup_prim_path}/looks/default_visual_material",
if not result:
    raise ValueError(f"Failed to bind material at path: {cls.headsup_prim_path}")
# Set the file attribute on the diffuseColorTex shader
stage = get_current_stage()
texture_shader_path = f"{cls.headsup_prim_path}/looks/default_visual_material/diffuseColorTex"
texture_shader = UsdShade.Shader(stage.GetPrimAtPath(texture_shader_path))
if texture_shader:
    texture_shader.CreateInput("file", Sdf.ValueTypeNames.Asset).Set(Sdf.AssetPath(image_path))
else:
    raise ValueError(f"Failed to bind material at path: {texture_shader_path}")
