How to programmatically create MeshCube using omni.isaac class like FixedCuboid?
Isaac Sim Version
4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Isaac Lab Version (if applicable)
1.2
1.1
1.0
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: RTX 4090
  • Driver Version: 560.94
Topic Description
Detailed Description
I want to apply a texture to a cube.
From my testing, I see that textures are only correctly applied to MeshCubes.
If you create a ShapeCube (seen as 2 in image above) or use one of the python classes FixedCuboid, or VisualCuboid the resulting primitive does not have the FaceAPI or the Normals attribute set on the mesh.
The only way I have found to programmatically create a MeshCube is using the Command
omni.kit.commands.execute(
    "CreateMeshPrimWithDefaultXform",
    prim_type="Cube",
    prim_path=cube_prim_path,
    select_new_prim=True,
    prepend_default_prim=True,
    above_ground=True,
Ideally, I would be able to use MeshCuboid class similar to FixedCuboid
If this class does not exist, what is the next best alternative?
Could I create a FixedCuboid and then manually apply the Face API and Normals attributes to the primitive?
If so, how can that be done?
Steps to Reproduce
N/A
Error Messages
N/A
Screenshots or Videos
See Above
Additional Information
What I’ve Tried
N/A
Related Issues
N/A
Additional Context
N/A
Hi there,
would wrapping the mesh in a GeometryPrim API work for you?
import omni.kit.commands
import omni.usd
from omni.isaac.core.prims.geometry_prim import GeometryPrim
omni.usd.get_context().new_stage()
    prim_type="Cube",
    prim_path="/World/MyCube",
    above_ground=True,
# Get the cube mesh prim
cube_mesh_prim = stage.GetPrimAtPath("/World/MyCube")
print(f"cube_mesh_prim type: {cube_mesh_prim.GetTypeName()}")
# Wrap the cube mesh prim as a GeometryPrim object
cube_geom_prim = GeometryPrim("/World/MyCube")
print(f"cube_geom_prim type: {type(cube_geom_prim)}")
The code you showed is still using the command to create the Mesh
The goal was to avoid that.
If we use the command, further modification to apply FaceAPI, Normals, Points. etc is not needed.
I think we would need to fine the appropriate USD Documentation for the Mesh API
OR perhaps something like this: CuboidMeshGenerator
In that case I think you would need to use vanilla USD code to create your desired mesh, or import an existing one from USD, then you wan wrap the prim into the desired isaac sim APIs.
Note that there is difference between primitive cube and mesh cube.
Given word “need”, I assume this is an indirect answer to the question about a MeshCuboid helper class and you are confirming: It does not exist.
And the answer to next question
is to use vanilla USD code to create your desired mesh
Is there an example of this somewhere?
Perhaps I can modify it to my needs.
I see code like this which may be related
mesh = UsdGeom.Mesh.Define(stage, path)
mesh.CreateSubdivisionSchemeAttr().Set(UsdGeom.Tokens.bilinear)
USD Terms and Concepts — Universal Scene Description 24.11 documentation
Yes, I showed this in the picture with Mesh cube on left and Shape cube on right. This difference is why textures do not render on primitives that despite having Mesh API, do NOT have (full) Mesh. Knowing what precisely the difference is would be helpful
