I’m trying to simulate soft bodies with Cuda device and torch back-end. I found that collision and simulation tetmeshes aren’t following the visualization meshes after the simulation has started, which is a problem that does not occur when simulating with the default world settings.
In the following images a cube has been generated at a certain height before simulation and then left dropping on the ground. The simulation tetmesh remains in the same position while the visualization mesh is actually following the physics constraints.
When running with the GPU pipeline, updates to states in the scene will not sync to USD. Therefore, values in the UI may appear wrong when simulation is running. Although objects may be updating in the Viewport, attribute values in the UI will not update along with them. Similarly, during simulation, any updates made through the USD APIs will not be synced with physics.
If I understand correctly, if the visualization does not work, also the USD API fails to work, and I should search for workarounds using the Physx SDK?
In my experience, trying to find workarounds using the PhysX SDK is very difficult (and painful).
One reason for that is mentioned in the second link I sent in my previous comment:
You cant access directly PhysX SDK, since that does have C++ API only,
Instead, I would first try to use the DeformablePrimView. You can import it via from omni.isaac.core.prims.soft.deformable_prim_view import DeformablePrimView.
There is no documentation for this yet, so you need to look into the source code to know which methods it has.
But with this class you are able to get the nodal positions of the simulation mesh via get_simulation_mesh_nodal_positions. This also works with the gpu pipeline.
Perhaps, this might be a good enough workaround for you for getting the position of the deformable prim.
Yes, thank you! I was unaware of the debug_draw feature, and it’s proving to be very useful!
Regarding the DeformablePrimView, it’s actually why I began simulations using the CUDA and Torch backend. I’ve attempted to use the get_simulation_nodal_positions, but it’s challenging to pinpoint the exact positions in relation to the object without running the simulation at least once to visually observe it. I understand that the DeformablePrimView.get_simulation_mesh_indicies() correspond to the nodal positions, but each time I use a different tetmesh resolution, the indices shift their position on the body.
I need the position for a pick and place task so knowing the exact position respect to the prim is really important.
Thanks again for the detailed answer, @Duce123!
