I’ve been generating a mesh terrain using a 2D height map by converting them to vertices and triangles, and then adding them to stage as follows:
def add_terrain_to_stage(stage, vertices, triangles, position=None, orientation=None):
num_faces = triangles.shape[0]
terrain_mesh = stage.DefinePrim("/World/terrain", "Mesh")
terrain_mesh.GetAttribute("points").Set(vertices)
terrain_mesh.GetAttribute("faceVertexIndices").Set(triangles.flatten())
terrain_mesh.GetAttribute("faceVertexCounts").Set(np.asarray([3]*num_faces))
terrain = XFormPrim(prim_path="/World/terrain",
name="terrain",
position=position,
orientation=orientation)
UsdPhysics.CollisionAPI.Apply(terrain.prim)
physx_collision_api = PhysxSchema.PhysxCollisionAPI.Apply(terrain.prim)
physx_collision_api.GetContactOffsetAttr().Set(0.02)
physx_collision_api.GetRestOffsetAttr().Set(0.00)
Now, I want to use a 2D RGB image of the same size as the height map, as texture for the mesh. How can I do that?
Hi @ahallak - To apply a texture to a mesh in USD, you need to create a material, bind it to the mesh, and then set the texture file path to the diffuse color input of the material’s shader. Here’s how you can do it:
from pxr import UsdShade, Sdf, UsdGeom
# Create a material.
material_path = Sdf.Path("/World/terrain_material")
material = UsdShade.Material.Define(stage, material_path)
# Create a shader for the material.
shader = UsdShade.Shader.Define(stage, material_path.AppendChild('PBRShader'))
shader.CreateIdAttr('UsdPreviewSurface')
# Create an input for the diffuse color.
diffuse_color_input = shader.CreateInput('diffuseColor', Sdf.ValueTypeNames.Color3f)
# Create a texture for the diffuse color.
texture_path = material_path.AppendChild('diffuseTexture')
texture = UsdShade.Shader.Define(stage, texture_path)
texture.CreateIdAttr('UsdUVTexture')
# Set the file path of the texture.
texture.CreateInput('file', Sdf.ValueTypeNames.Asset).Set('path/to/your/texture.png')
# Connect the texture to the diffuse color input.
texture.CreateOutput('rgb', Sdf.ValueTypeNames.Float3).ConnectToSource(diffuse_color_input)
# Bind the material to the mesh.
UsdShade.MaterialBindingAPI(terrain_mesh).Bind(material)
This code creates a material with a PBR shader and a texture for the diffuse color. The texture file path is set to the ‘file’ input of the texture shader. The ‘rgb’ output of the texture shader is then connected to the ‘diffuseColor’ input of the PBR shader. Finally, the material is bound to the mesh using the UsdShade.MaterialBindingAPI.
Please replace ‘path/to/your/texture.png’ with the actual path to your texture file.
Thank you very much for your reply.
I pasted the code you sent, while it doesn’t crash, it also doesn’t seem to work.
I’ve tried replacing the png with jpeg, and also instead of using my desired image using a simple blue screen from online. None of them shows.
I do see in the IsaacSim screen opening up the material in the right path, and seemed to be binded.
Any idea what am I doing wrong?
The plot thickens…
Even though your code didn’t pull through, it led me to this online source Create a UsdPreviewSurface Material — dev-guide latest documentation
The last part was very similar to what you proposed, so I added everything without understanding anything and got the following code:
# Add texture
shader.CreateInput("roughness", Sdf.ValueTypeNames.Float).Set(0.5)
shader.CreateInput("metallic", Sdf.ValueTypeNames.Float).Set(0.0)
# texture_path = material_path.AppendChild('diffuseTexture')
texture_path = material_path.AppendChild('DiffuseColorTx')
texture.CreateInput('file', Sdf.ValueTypeNames.Asset).Set('/home/ahallak/Downloads/rgb_map5.png')
# texture.CreateInput('file', Sdf.ValueTypeNames.Asset).Set('/home/ahallak/Downloads/Solid_blue.png')
shader.CreateInput("diffuseColor", Sdf.ValueTypeNames.Color3f).ConnectToSource(texture.ConnectableAPI(), 'rgb')
material.CreateSurfaceOutput().ConnectToSource(shader.ConnectableAPI(), "surface")
Now this code, worked on an online png image I found, but I couldn’t get it to work on a HxWx3 numpy array have:
- when I try to save it to PNG with matplotlib.Image.imsave, nothing happens in the rendering.
- when I save it using cv2.imwrite, it only appears in grayscale for both 0-1 float values when saved as png, or 0-255 numpy.uint8 values when saved as jpg. So I couldn’t get color and I have no idea why.
Do you understand what was missing from your original snippet, maybe I’m merging the sources wrong?
Any idea how to save a HxWx3 numpy array as an image in a way which is compatible with the texture?
OK, new hint - by playing with additional PNGs, I’ve realized that although some don’t work, these that do result in a monochromatic rendering - either all are shades of blue, or shades of red, or shades of grayscale. I couldn’t find any clue to why this may happen in the snippet, maybe you have an idea.
