Applying material on terrain mesh from OmnilsaacGymEnvs
I am building an extension that generate rough terrain environment in isaac sim. I generate vertices and faces using the source code provided by omniIsaacGymEnvs:
Once the meshes are imported into the stage and can be visualize through the viewport, I want to apply a material texture such as grass for instance. So far I am doing it manually via the GUI but the rendering does not appear. Below is an video example that shows the problem:
You will see that the terrain meshes generated through python api do not change when a texture is applied whereas a plane mesh created form the GUI displays the right texture.
Here is code below that consist of 3 files: terrain_creation.py, terrain_generation_extension.py, terrain_utils.py.
scripts.zip (8.1 KB)
Best,
Yohan
Hi there, thanks for reporting this. I suspect this is because the generated terrain mesh is missing the normals attributes. We will take a further look at this issue internally.
I implemented the vertices normals with the following functions:
def compute_face_normals(faces, vertices):
    n_F = faces.shape[0]
    face_normals = np.zeros((n_F, 3))
    for i in range(n_F):
        a = faces[i, 0]
        b = faces[i, 1]
        c = faces[i, 2]
        A = vertices[a, :]
        B = vertices[b, :]
        C = vertices[c, :]
        BA = B - A
        CA = C - A
        face_normal = np.cross(BA, CA)
        face_normal /= np.linalg.norm(face_normal)
        face_normals[i, :] = face_normal
    return face_normals
def compute_vertex_normals(faces, vertices):
    n_V = vertices.shape[0]
    vertex_normals = np.zeros((n_V, 3))
    # Compute face normals
    face_normals = compute_face_normals(vertices, faces)
    # Accumulate face normals for each vertex
    for i in range(faces.shape[0]):
        a = faces[i, 0]
        b = faces[i, 1]
        c = faces[i, 2]
        vertex_normals[a, :] += face_normals[i, :]
        vertex_normals[b, :] += face_normals[i, :]
        vertex_normals[c, :] += face_normals[i, :]
    # Normalize vertex normals
    vertex_normals /= np.linalg.norm(vertex_normals, axis=1)[:, np.newaxis]
    return vertex_normals
But the meshes still do not show the right texture when a material is assigned to them.
Hi @kellyg - Any news from your side?
Best,
Yohan
Hi @yohan.legars - This will be fixed in the future Isaac Sim release (Expected around June month)
