Argus API - Settings.h
I want to control the ISP and thereby change the parameters of my video stream using Argus and I can find that those functionalities are present in Settings.h.Here I can see the controls for Auto exposure,white balance and so on.I can control these values before starting the stream but we have a requirement where on run time(as the stream is running) we should be able to change the parameters like saturation,white balance etc.Can you suggest a way to do so.
Thanks in Advance!
Reference to the argus_camera to modify the gainrange/exposurerange/… for it.
There doesn’t have directly control the gain/exposure API for it.
You can have set the MIN and MAX to the same to force AE alg to set the value as you want.
