Hi folks,
I was adding a driver for imx390 on tx2, base on r28.1 NVIDIA kernel source.
There is a issue that I can always use nvgstcapture to get video, but argus_camera is not able to get capture.
The argus_camera only get one frame(maybe a very quick while), after that it will be stuck.
Here I post some debug log:
1. kmesg
[ 255.201202] imx390 30-001a: imx390_set_frame_rate: val: 125829120, , frame_length: 2250
[ 255.210291] imx390 30-001a: imx390_set_exposure: val: 139810
[ 255.238929] imx390 30-001a: imx390_set_group_hold: val: 1
[ 255.244732] imx390 30-001a: imx390_set_exposure: val: 139796
[ 255.250394] imx390 30-001a: imx390_set_group_hold: val: 0
[ 255.257443] imx390 30-001a: imx390_set_group_hold: val: 1
[ 255.263242] imx390 30-001a: imx390_set_gain: gain reg: 0, db: 0
[ 255.269951] imx390 30-001a: imx390_set_group_hold: val: 0
[ 257.998938] imx390 30-001a: imx390_s_stream++ enable 0
[ 258.004756] imx390 30-001a: imx390_power_off: power off
[ 260.492656] argus_camera[4963]: unhandled level 2 translation fault (11) at 0x00000004, esr 0x92000006
[ 260.502163] pgd = ffffffc1a9612000
[ 260.505620] [00000004] *pgd=0000000234dc7003, *pud=0000000234dc7003, *pmd=0000000000000000
[ 260.515688] CPU: 4 PID: 4963 Comm: argus_camera Not tainted 4.4.38-test #12
[ 260.522715] Hardware name: quill (DT)
[ 260.526458] task: ffffffc1c0cd8000 ti: ffffffc1a9664000 task.ti: ffffffc1a9664000
[ 260.534007] PC is at 0x7f9feb63f4
[ 260.537469] LR is at 0x7f9feb63e4
[ 260.540899] pc : [<0000007f9feb63f4>] lr : [<0000007f9feb63e4>] pstate: 60000000
[ 260.548383] sp : 0000007fe77812d0
[ 260.551816] x29: 0000007fe7781350 x28: 0000000000000000
[ 260.557365] x27: 0000000000000000 x26: 0000000000000000
[ 260.562986] x25: 0000000000000000 x24: 0000000000000000
[ 260.568327] x23: 0000000000000000 x22: 0000000000000000
[ 260.573659] x21: 0000000000000000 x20: 000000000072cc80
[ 260.579016] x19: 0000007fe7781328 x18: 0000000003800027
[ 260.584344] x17: 0000007f9efb9d30 x16: 0000007f9ee6e4a0
[ 260.589681] x15: 0000007fa00d1cc0 x14: 6c632f74656b636f
[ 260.595022] x13: 732f6370722f6372 x12: 73206d6f72662067
[ 260.600354] x11: 6e6974616761706f x10: 72702820203a6574
[ 260.605683] x9 : 61745364696c6176 x8 : 0000000000000040
[ 260.611020] x7 : 0000000000000000 x6 : 0000007fe777e44c
[ 260.616349] x5 : 0000000000000000 x4 : 0000000000000000
[ 260.621680] x3 : 0000000000000000 x2 : 0000000000000001
[ 260.627022] x1 : 0000000000000000 x0 : 0000007fe7781328
[ 260.634014] Library at 0x7f9feb63f4: 0x7f9fe5d000 /usr/lib/aarch64-linux-gnu/tegra/libargus_socketclient.so
[ 260.643750] Library at 0x7f9feb63e4: 0x7f9fe5d000 /usr/lib/aarch64-linux-gnu/tegra/libargus_socketclient.so
[ 260.653483] vdso base = 0x7fa00d0000
2. argus_daemon log
PowerServiceUtils:calculateReqClock: entered
PowerServiceHw:addRequest: table size: before: 0, after:1
request table for VI 0:
req[0]: guID=0, stageID=SensorCapture
req[0]: inW=1936, inH=1100, inBpp = 12, fps=30
req[0]: outW=1936, outH=1100, outBpp=12
req[0]: out1W=0, out1H=0, out1Bpp=0
req[0]: out2W=0, out2H=0, out2Bpp=0
req[0]: clock=25987500, pixelRate=148500000, timeout=900
req[0]: isoBw=311844, timeout=900
req[0]: non_isoBw=0, timeout=900
request table for CSI 0:
req[0]: clock=36196872, pixelRate=148500000, timeout=900
req[0]: isoBw=0, timeout=900
PowerServiceHwVi:setIso: m_bwVal_Iso=311844
PowerServiceHw:setClock: PowerServiceHw[1]: requested_clock_Hz=25987500
PowerServiceHw:setClock: PowerServiceHw[0]: requested_clock_Hz=36196872
PowerServiceCore:setCameraBw: totalIsoBw=311844
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
Created fiber 0x7f48000d10 for CC 103 globalID 103 session 0
Thread 5 is working on CC 103 session 0 globalID 103 step 0
Fiber 0x7f48000d10 is aborting in CC 103 Session 0
FiberScheduler: cc 103 session 0, fiber 0x7f48000d10 aborted
launchCC abort cc 104 session 0
Created fiber 0x7f4400d6c0 for CC 104 globalID 104 session 0
Thread 6 is working on CC 104 session 0 globalID 104 step 0
Fiber 0x7f4400d6c0 is aborting in CC 104 Session 0
SCF: Error Timeout: (propagating from src/api/Session.cpp, function capture(), line 830)
FiberScheduler: fiber 0x7f48000d10 exiting
FiberScheduler: cc 104 session 0, fiber 0x7f4400d6c0 aborted
Thread 5 getting next capture
(Argus) Error Timeout: Failed to submit first capture request (propagating from src/api/CaptureSessionImpl.cpp, function submitCaptureRequests(), line 311)
disposing CC 103 Session 0
Thread 5 is waiting
Thread 8 is waiting
Thread 7 is waiting
(Argus) Error Timeout: (propagating from src/api/CaptureSessionImpl.cpp, function threadFunction(), line 777)
FiberScheduler: fiber 0x7f4400d6c0 exiting
Thread 6 getting next capture
Thread 9 is waiting
Thread 6 is waiting
Thread 10 is waiting
PowerServiceHw:addRequest: table size: before: 1, after:2
req[1]: guID=0, stageID=SensorIspCapture
req[1]: inW=1936, inH=1100, inBpp = 12, fps=30
req[1]: outW=1936, outH=1100, outBpp=16
req[1]: out1W=0, out1H=0, out1Bpp=0
req[1]: out2W=0, out2H=0, out2Bpp=0
req[1]: clock=25987500, pixelRate=148500000, timeout=450
req[1]: isoBw=0, timeout=450
req[1]: non_isoBw=0, timeout=450
req[1]: clock=36196872, pixelRate=148500000, timeout=450
request table for ISP 0:
req[0]: guID=0, stageID=SensorIspCapture
req[0]: outW=130, outH=74, outBpp=16
req[0]: out1W=320, out1H=200, out1Bpp=16
req[0]: out2W=320, out2H=200, out2Bpp=16
req[0]: clock=81675000, pixelRate=148500000, timeout=450
req[0]: isoBw=980100, timeout=450
req[0]: non_isoBw=0, timeout=450
PowerServiceCore:handleRequests: timePassed = 2398
PowerServiceHwIsp:setLaBw: m_bwVal_Iso=980100 and m_bwVal_NonIso=0 KBpS
PowerServiceHw:setClock: PowerServiceHw[2]: requested_clock_Hz=81675000
PowerServiceCore:setCameraBw: totalIsoBw=980100
req[0]: clock=81675000, pixelRate=148500000, timeout=431
req[0]: isoBw=980100, timeout=431
req[0]: non_isoBw=0, timeout=431
req[1]: outW=1936, outH=1100, outBpp=12
req[1]: out1W=320, out1H=200, out1Bpp=16
req[1]: out2W=640, out2H=364, out2Bpp=13
req[1]: clock=81675000, pixelRate=148500000, timeout=450
req[1]: isoBw=837168, timeout=450
Issue bubble captures
FiberScheduler: cc 101, session 0, fiber 0x7f480008c0 succeeded async operation
Thread 12 is working on CC 101 session 0 globalID 101 step 8
exposureTime=0.033330 analogGain=1.000100 digitalGain=1.000000 commonGain=0.033333 expComp=1.000000
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 3620.250
CC 101 session 0 completed step 8 in fiber 0x7f480008c0
CC 101 session 0 completed step 9 in fiber 0x7f480008c0
CC 101 session 0 completed step 10 in fiber 0x7f480008c0
NV AF analysis algorithm is active.
AfAnalysis cc 101 push FK_ISP_RUN_NUMBER=1.
CC 101 session 0 completed step 11 in fiber 0x7f480008c0
CC 101 session 0 completed step 12 in fiber 0x7f480008c0
CC 101 session 0 completed step 13 in fiber 0x7f480008c0
CC 101 session 0 completed step 14 in fiber 0x7f480008c0
CC 101 session 0 completed step 15 in fiber 0x7f480008c0
CC 101 session 0 completed step 16 in fiber 0x7f480008c0
CC 101 session 0 completed step 17 in fiber 0x7f480008c0
FiberScheduler: cc 101, session 0, fiber 0x7f480008c0 complete
FiberScheduler: fiber 0x7f480008c0 exiting
Thread 12 getting next capture
disposing CC 101 Session 0
Thread 11 is waiting
Thread 1 is waiting
Thread 12 is waiting
FiberScheduler: cc 102, session 0, fiber 0x7f48000b70 succeeded async operation
Thread 3 is working on CC 102 session 0 globalID 102 step 8
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 3621.537
CC 102 session 0 completed step 8 in fiber 0x7f48000b70
CC 102 session 0 completed step 9 in fiber 0x7f48000b70
CC 102 session 0 completed step 10 in fiber 0x7f48000b70
AfAnalysis cc 102 push FK_ISP_RUN_NUMBER=2.
CC 102 session 0 completed step 11 in fiber 0x7f48000b70
CC 102 session 0 completed step 12 in fiber 0x7f48000b70
CC 102 session 0 completed step 13 in fiber 0x7f48000b70
CC 102 session 0 completed step 14 in fiber 0x7f48000b70
CC 102 session 0 completed step 15 in fiber 0x7f48000b70
CC 102 session 0 completed step 16 in fiber 0x7f48000b70
CC 102 session 0 completed step 17 in fiber 0x7f48000b70
FiberScheduler: cc 102, session 0, fiber 0x7f48000b70 complete
FiberScheduler: fiber 0x7f48000b70 exiting
Thread 3 getting next capture
disposing CC 102 Session 0
Thread 3 is waiting
Thread 4 is waiting
Thread 2 is waiting
PowerServiceHw:updateRequests: table size: before: 2, after:2
req[0]: clock=81675000, pixelRate=148500000, timeout=417
req[0]: isoBw=980100, timeout=417
req[0]: non_isoBw=0, timeout=417
req[1]: clock=81675000, pixelRate=148500000, timeout=0
req[1]: isoBw=837168, timeout=0
req[1]: non_isoBw=0, timeout=0
3. cat /sys/kernel/debug/tracing/trace
entries-in-buffer/entries-written: 187/187 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/5:1-114 [005] ...1 74.324699: rtos_queue_peek_from_isr_failed: tstamp:2636899438 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 74.324703: rtcpu_start: tstamp:2636900190
kworker/5:1-114 [005] ...1 74.480694: rtos_queue_peek_from_isr_failed: tstamp:2641900349 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 74.636695: rtos_queue_peek_from_isr_failed: tstamp:2646900810 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 74.688707: rtos_queue_peek_from_isr_failed: tstamp:2649383435 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 74.740706: rtos_queue_peek_from_isr_failed: tstamp:2650167809 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 74.740710: rtcpu_start: tstamp:2650168688
kworker/5:1-114 [005] ...1 74.896728: rtos_queue_peek_from_isr_failed: tstamp:2655168686 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 75.052733: rtos_queue_peek_from_isr_failed: tstamp:2660169226 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 75.208747: rtos_queue_peek_from_isr_failed: tstamp:2665169736 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 75.364746: rtos_queue_peek_from_isr_failed: tstamp:2670170235 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 75.520686: rtos_queue_peek_from_isr_failed: tstamp:2675170692 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 75.680691: rtos_queue_peek_from_isr_failed: tstamp:2680171216 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 75.836748: rtos_queue_peek_from_isr_failed: tstamp:2685171810 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 75.992731: rtos_queue_peek_from_isr_failed: tstamp:2690172260 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 76.200724: rtos_queue_peek_from_isr_failed: tstamp:2695172766 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 76.356689: rtos_queue_peek_from_isr_failed: tstamp:2700173226 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 76.512696: rtos_queue_peek_from_isr_failed: tstamp:2705173752 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 76.668687: rtos_queue_peek_from_isr_failed: tstamp:2710174263 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 76.824685: rtos_queue_peek_from_isr_failed: tstamp:2715174770 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 76.980686: rtos_queue_peek_from_isr_failed: tstamp:2720175261 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 77.136685: rtos_queue_peek_from_isr_failed: tstamp:2725175773 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 77.188693: rtcpu_vinotify_handle_msg: tstamp:2727059620 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2727059192 data:0x00000000
kworker/5:1-114 [005] ...1 77.188695: rtcpu_vinotify_handle_msg: tstamp:2727066464 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2727066049 data:0x00000001
kworker/5:1-114 [005] ...1 77.188696: rtcpu_vinotify_handle_msg: tstamp:2727575734 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2727575148 data:0x044b0002
kworker/5:1-114 [005] ...1 77.188697: rtcpu_vinotify_handle_msg: tstamp:2727575842 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2727575170 data:0x00000000
kworker/5:1-114 [005] ...1 77.240687: rtcpu_vinotify_handle_msg: tstamp:2728101289 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2728100864 data:0x00000000
kworker/5:1-114 [005] ...1 77.240689: rtcpu_vinotify_handle_msg: tstamp:2728108132 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2728107721 data:0x00000001
kworker/5:1-114 [005] ...1 77.240690: rtcpu_vinotify_handle_msg: tstamp:2728617402 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2728616820 data:0x044b0002
kworker/5:1-114 [005] ...1 77.240691: rtcpu_vinotify_handle_msg: tstamp:2728617510 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2728616841 data:0x00000000
kworker/5:1-114 [005] ...1 77.240691: rtcpu_vinotify_handle_msg: tstamp:2729142953 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2729142536 data:0x00000000
kworker/5:1-114 [005] ...1 77.240692: rtcpu_vinotify_handle_msg: tstamp:2729149802 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2729149392 data:0x00000001
kworker/5:1-114 [005] ...1 77.292701: rtcpu_vinotify_handle_msg: tstamp:2729659070 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2729658491 data:0x044b0002
kworker/5:1-114 [005] ...1 77.292704: rtcpu_vinotify_handle_msg: tstamp:2729659175 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2729658513 data:0x00000000
kworker/5:1-114 [005] ...1 77.292706: rtos_queue_peek_from_isr_failed: tstamp:2730176267 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 77.292707: rtcpu_vinotify_handle_msg: tstamp:2730184618 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2730184207 data:0x00000000
kworker/5:1-114 [005] ...1 77.292708: rtcpu_vinotify_handle_msg: tstamp:2730191473 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2730191064 data:0x00000001
kworker/5:1-114 [005] ...1 77.292709: rtcpu_vinotify_handle_msg: tstamp:2730700757 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2730700163 data:0x044b0002
kworker/5:1-114 [005] ...1 77.292709: rtcpu_vinotify_handle_msg: tstamp:2730700870 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2730700184 data:0x00000000
kworker/5:1-114 [005] ...1 77.344688: rtcpu_vinotify_handle_msg: tstamp:2731226302 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2731225879 data:0x00000000
kworker/5:1-114 [005] ...1 77.344691: rtcpu_vinotify_handle_msg: tstamp:2731233155 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2731232736 data:0x00000001
kworker/5:1-114 [005] ...1 77.344691: rtcpu_vinotify_handle_msg: tstamp:2731742420 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2731741835 data:0x044b0002
kworker/5:1-114 [005] ...1 77.344692: rtcpu_vinotify_handle_msg: tstamp:2731742527 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2731741857 data:0x00000000
kworker/5:1-114 [005] ...1 77.344693: rtcpu_vinotify_handle_msg: tstamp:2732267967 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2732267551 data:0x00000000
kworker/5:1-114 [005] ...1 77.344694: rtcpu_vinotify_handle_msg: tstamp:2732274816 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2732274407 data:0x00000001
kworker/5:1-114 [005] ...1 77.396685: rtcpu_vinotify_handle_msg: tstamp:2732784085 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2732783506 data:0x044b0002
kworker/5:1-114 [005] ...1 77.396686: rtcpu_vinotify_handle_msg: tstamp:2732784193 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2732783528 data:0x00000000
kworker/5:1-114 [005] ...1 77.396687: rtcpu_vinotify_handle_msg: tstamp:2733309639 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2733309222 data:0x00000000
kworker/5:1-114 [005] ...1 77.396688: rtcpu_vinotify_handle_msg: tstamp:2733316489 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2733316079 data:0x00000001
kworker/5:1-114 [005] ...1 77.396689: rtcpu_vinotify_handle_msg: tstamp:2733825757 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2733825178 data:0x044b0002
kworker/5:1-114 [005] ...1 77.396689: rtcpu_vinotify_handle_msg: tstamp:2733825864 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2733825200 data:0x00000000
kworker/5:1-114 [005] ...1 77.448684: rtcpu_vinotify_handle_msg: tstamp:2734351309 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2734350895 data:0x00000000
kworker/5:1-114 [005] ...1 77.448686: rtcpu_vinotify_handle_msg: tstamp:2734358164 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2734357750 data:0x00000001
kworker/5:1-114 [005] ...1 77.448687: rtcpu_vinotify_handle_msg: tstamp:2734867426 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2734866849 data:0x044b0002
kworker/5:1-114 [005] ...1 77.448688: rtcpu_vinotify_handle_msg: tstamp:2734867534 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2734866872 data:0x00000000
kworker/5:1-114 [005] ...1 77.448690: rtos_queue_peek_from_isr_failed: tstamp:2735176773 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 77.448690: rtcpu_vinotify_handle_msg: tstamp:2735392982 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2735392567 data:0x00000000
kworker/5:1-114 [005] ...1 77.448691: rtcpu_vinotify_handle_msg: tstamp:2735399834 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2735399423 data:0x00000001
kworker/5:1-114 [005] ...1 77.500684: rtcpu_vinotify_handle_msg: tstamp:2735909099 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2735908522 data:0x044b0002
kworker/5:1-114 [005] ...1 77.500686: rtcpu_vinotify_handle_msg: tstamp:2735909208 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2735908544 data:0x00000000
kworker/5:1-114 [005] ...1 77.500686: rtcpu_vinotify_handle_msg: tstamp:2736434653 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2736434239 data:0x00000000
kworker/5:1-114 [005] ...1 77.500687: rtcpu_vinotify_handle_msg: tstamp:2736441507 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2736441096 data:0x00000001
kworker/5:1-114 [005] ...1 77.500688: rtcpu_vinotify_handle_msg: tstamp:2736950773 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2736950195 data:0x044b0002
kworker/5:1-114 [005] ...1 77.500689: rtcpu_vinotify_handle_msg: tstamp:2736950882 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2736950216 data:0x00000000
kworker/5:1-114 [005] ...1 77.552683: rtcpu_vinotify_handle_msg: tstamp:2737476327 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2737475911 data:0x00000000
kworker/5:1-114 [005] ...1 77.552684: rtcpu_vinotify_handle_msg: tstamp:2737483176 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2737482768 data:0x00000001
kworker/5:1-114 [005] ...1 77.552685: rtcpu_vinotify_handle_msg: tstamp:2737992444 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2737991867 data:0x044b0002
kworker/5:1-114 [005] ...1 77.552686: rtcpu_vinotify_handle_msg: tstamp:2737992551 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2737991888 data:0x00000000
kworker/5:1-114 [005] ...1 77.552687: rtcpu_vinotify_handle_msg: tstamp:2738517998 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2738517583 data:0x00000000
kworker/5:1-114 [005] ...1 77.552687: rtcpu_vinotify_handle_msg: tstamp:2738524848 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2738524439 data:0x00000001
kworker/5:1-114 [005] ...1 77.604681: rtcpu_vinotify_handle_msg: tstamp:2739034117 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2739033538 data:0x044b0002
kworker/5:1-114 [005] ...1 77.604683: rtcpu_vinotify_handle_msg: tstamp:2739034226 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2739033560 data:0x00000000
kworker/5:1-114 [005] ...1 77.604683: rtcpu_vinotify_handle_msg: tstamp:2739559668 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2739559255 data:0x00000000
kworker/5:1-114 [005] ...1 77.604684: rtcpu_vinotify_handle_msg: tstamp:2739566517 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2739566111 data:0x00000001
kworker/5:1-114 [005] ...1 77.604685: rtcpu_vinotify_handle_msg: tstamp:2740075790 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2740075210 data:0x044b0002
kworker/5:1-114 [005] ...1 77.604686: rtcpu_vinotify_handle_msg: tstamp:2740075899 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2740075231 data:0x00000000
kworker/5:1-114 [005] ...1 77.604687: rtos_queue_peek_from_isr_failed: tstamp:2740177283 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 77.656684: rtcpu_vinotify_handle_msg: tstamp:2740601342 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2740600926 data:0x00000000
kworker/5:1-114 [005] ...1 77.656686: rtcpu_vinotify_handle_msg: tstamp:2740608190 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2740607783 data:0x00000001
kworker/5:1-114 [005] ...1 77.656687: rtcpu_vinotify_handle_msg: tstamp:2741117464 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2741116882 data:0x044b0002
kworker/5:1-114 [005] ...1 77.656687: rtcpu_vinotify_handle_msg: tstamp:2741117572 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2741116904 data:0x00000000
kworker/5:1-114 [005] ...1 77.656688: rtcpu_vinotify_handle_msg: tstamp:2741643013 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2741642598 data:0x00000000
kworker/5:1-114 [005] ...1 77.656689: rtcpu_vinotify_handle_msg: tstamp:2741649863 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2741649456 data:0x00000001
kworker/5:1-114 [005] ...1 77.656690: rtcpu_vinotify_handle_msg: tstamp:2742159132 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2742158555 data:0x044b0002
kworker/5:1-114 [005] ...1 77.656691: rtcpu_vinotify_handle_msg: tstamp:2742159240 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2742158577 data:0x00000000
kworker/5:1-114 [005] ...1 77.708684: rtcpu_vinotify_handle_msg: tstamp:2742684687 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2742684271 data:0x00000000
kworker/5:1-114 [005] ...1 77.708685: rtcpu_vinotify_handle_msg: tstamp:2742691536 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2742691128 data:0x00000001
kworker/5:1-114 [005] ...1 77.708686: rtcpu_vinotify_handle_msg: tstamp:2743200808 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2743200227 data:0x044b0002
kworker/5:1-114 [005] ...1 77.708687: rtcpu_vinotify_handle_msg: tstamp:2743200914 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2743200248 data:0x00000000
kworker/5:1-114 [005] ...1 77.708687: rtcpu_vinotify_handle_msg: tstamp:2743726360 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2743725943 data:0x00000000
kworker/5:1-114 [005] ...1 77.708688: rtcpu_vinotify_handle_msg: tstamp:2743733209 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2743732800 data:0x00000001
kworker/5:1-114 [005] ...1 77.760688: rtcpu_vinotify_handle_msg: tstamp:2744242477 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2744241900 data:0x044b0002
kworker/5:1-114 [005] ...1 77.760691: rtcpu_vinotify_handle_msg: tstamp:2744242583 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2744241921 data:0x00000000
kworker/5:1-114 [005] ...1 77.760691: rtcpu_vinotify_handle_msg: tstamp:2744768032 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2744767616 data:0x00000000
kworker/5:1-114 [005] ...1 77.760692: rtcpu_vinotify_handle_msg: tstamp:2744774881 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2744774473 data:0x00000001
kworker/5:1-114 [005] ...1 77.760694: rtos_queue_peek_from_isr_failed: tstamp:2745177789 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 77.760695: rtcpu_vinotify_handle_msg: tstamp:2745284150 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2745283572 data:0x044b0002
kworker/5:1-114 [005] ...1 77.760696: rtcpu_vinotify_handle_msg: tstamp:2745284256 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2745283593 data:0x00000000
kworker/5:1-114 [005] ...1 77.812689: rtcpu_vinotify_handle_msg: tstamp:2745809705 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2745809288 data:0x00000000
kworker/5:1-114 [005] ...1 77.812692: rtcpu_vinotify_handle_msg: tstamp:2745816553 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2745816145 data:0x00000001
kworker/5:1-114 [005] ...1 77.812692: rtcpu_vinotify_handle_msg: tstamp:2746325826 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2746325244 data:0x044b0002
kworker/5:1-114 [005] ...1 77.812693: rtcpu_vinotify_handle_msg: tstamp:2746325932 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2746325265 data:0x00000000
kworker/5:1-114 [005] ...1 77.812694: rtcpu_vinotify_handle_msg: tstamp:2746851373 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2746850960 data:0x00000000
kworker/5:1-114 [005] ...1 77.812695: rtcpu_vinotify_handle_msg: tstamp:2746858225 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2746857817 data:0x00000001
kworker/5:1-114 [005] ...1 77.864685: rtcpu_vinotify_handle_msg: tstamp:2747367493 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2747366917 data:0x044b0002
kworker/5:1-114 [005] ...1 77.864686: rtcpu_vinotify_handle_msg: tstamp:2747367601 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2747366938 data:0x00000000
kworker/5:1-114 [005] ...1 77.864687: rtcpu_vinotify_handle_msg: tstamp:2747893047 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2747892633 data:0x00000000
kworker/5:1-114 [005] ...1 77.864688: rtcpu_vinotify_handle_msg: tstamp:2747899900 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2747899489 data:0x00000001
kworker/5:1-114 [005] ...1 77.864688: rtcpu_vinotify_handle_msg: tstamp:2748409164 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2748408588 data:0x044b0002
kworker/5:1-114 [005] ...1 77.864689: rtcpu_vinotify_handle_msg: tstamp:2748409270 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2748408609 data:0x00000000
kworker/5:1-114 [005] ...1 77.916682: rtcpu_vinotify_handle_msg: tstamp:2748934719 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2748934305 data:0x00000000
kworker/5:1-114 [005] ...1 77.916684: rtcpu_vinotify_handle_msg: tstamp:2748941569 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2748941161 data:0x00000001
kworker/5:1-114 [005] ...1 77.916685: rtcpu_vinotify_handle_msg: tstamp:2749450836 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2749450260 data:0x044b0002
kworker/5:1-114 [005] ...1 77.916686: rtcpu_vinotify_handle_msg: tstamp:2749450942 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2749450282 data:0x00000000
kworker/5:1-114 [005] ...1 77.916686: rtcpu_vinotify_handle_msg: tstamp:2749976389 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2749975977 data:0x00000000
kworker/5:1-114 [005] ...1 77.916688: rtcpu_vinotify_handle_msg: tstamp:2749983242 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2749982834 data:0x00000001
kworker/5:1-114 [005] ...1 77.916690: rtos_queue_peek_from_isr_failed: tstamp:2750178303 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 77.968718: rtcpu_vinotify_handle_msg: tstamp:2750492511 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2750491933 data:0x044b0002
kworker/5:1-114 [005] ...1 77.968720: rtcpu_vinotify_handle_msg: tstamp:2750492619 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2750491955 data:0x00000000
kworker/5:1-114 [005] ...1 77.968721: rtcpu_vinotify_handle_msg: tstamp:2751018066 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2751017650 data:0x00000000
kworker/5:1-114 [005] ...1 77.968722: rtcpu_vinotify_handle_msg: tstamp:2751024915 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2751024507 data:0x00000001
kworker/5:1-114 [005] ...1 77.968723: rtcpu_vinotify_handle_msg: tstamp:2751534184 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2751533606 data:0x044b0002
kworker/5:1-114 [005] ...1 77.968723: rtcpu_vinotify_handle_msg: tstamp:2751534291 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2751533628 data:0x00000000
kworker/5:1-114 [005] ...1 78.020689: rtcpu_vinotify_handle_msg: tstamp:2752059739 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2752059322 data:0x00000000
kworker/5:1-114 [005] ...1 78.020692: rtcpu_vinotify_handle_msg: tstamp:2752066587 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2752066179 data:0x00000001
kworker/5:1-114 [005] ...1 78.020693: rtcpu_vinotify_handle_msg: tstamp:2752575856 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2752575279 data:0x044b0002
kworker/5:1-114 [005] ...1 78.020694: rtcpu_vinotify_handle_msg: tstamp:2752575965 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2752575301 data:0x00000000
kworker/5:1-114 [005] ...1 78.020695: rtcpu_vinotify_handle_msg: tstamp:2753101409 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2753100995 data:0x00000000
kworker/5:1-114 [005] ...1 78.020695: rtcpu_vinotify_handle_msg: tstamp:2753108256 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2753107851 data:0x00000001
kworker/5:1-114 [005] ...1 78.072689: rtcpu_vinotify_handle_msg: tstamp:2753617530 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2753616951 data:0x044b0002
kworker/5:1-114 [005] ...1 78.072691: rtcpu_vinotify_handle_msg: tstamp:2753617637 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2753616973 data:0x00000000
kworker/5:1-114 [005] ...1 78.072692: rtcpu_vinotify_handle_msg: tstamp:2754143084 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2754142668 data:0x00000000
kworker/5:1-114 [005] ...1 78.072693: rtcpu_vinotify_handle_msg: tstamp:2754149932 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2754149524 data:0x00000001
kworker/5:1-114 [005] ...1 78.072694: rtcpu_vinotify_handle_msg: tstamp:2754659201 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2754658624 data:0x044b0002
kworker/5:1-114 [005] ...1 78.072695: rtcpu_vinotify_handle_msg: tstamp:2754659308 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2754658645 data:0x00000000
kworker/5:1-114 [005] ...1 78.072697: rtos_queue_peek_from_isr_failed: tstamp:2755178804 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 78.072698: rtcpu_vinotify_handle_msg: tstamp:2755184751 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2755184340 data:0x00000000
kworker/5:1-114 [005] ...1 78.072698: rtcpu_vinotify_handle_msg: tstamp:2755191605 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2755191196 data:0x00000001
kworker/5:1-114 [005] ...1 78.124686: rtcpu_vinotify_handle_msg: tstamp:2755700876 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2755700296 data:0x044b0002
kworker/5:1-114 [005] ...1 78.124688: rtcpu_vinotify_handle_msg: tstamp:2755700984 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2755700317 data:0x00000000
kworker/5:1-114 [005] ...1 78.124689: rtcpu_vinotify_handle_msg: tstamp:2756226426 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2756226012 data:0x00000000
kworker/5:1-114 [005] ...1 78.124689: rtcpu_vinotify_handle_msg: tstamp:2756233279 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2756232869 data:0x00000001
kworker/5:1-114 [005] ...1 78.124690: rtcpu_vinotify_handle_msg: tstamp:2756742547 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2756741968 data:0x044b0002
kworker/5:1-114 [005] ...1 78.124691: rtcpu_vinotify_handle_msg: tstamp:2756742653 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2756741989 data:0x00000000
kworker/5:1-114 [005] ...1 78.176683: rtcpu_vinotify_handle_msg: tstamp:2757268098 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2757267685 data:0x00000000
kworker/5:1-114 [005] ...1 78.176684: rtcpu_vinotify_handle_msg: tstamp:2757274954 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2757274541 data:0x00000001
kworker/5:1-114 [005] ...1 78.176685: rtcpu_vinotify_handle_msg: tstamp:2757784217 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2757783640 data:0x044b0002
kworker/5:1-114 [005] ...1 78.176686: rtcpu_vinotify_handle_msg: tstamp:2757784325 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2757783661 data:0x00000000
kworker/5:1-114 [005] ...1 78.176687: rtcpu_vinotify_handle_msg: tstamp:2758309772 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2758309356 data:0x00000000
kworker/5:1-114 [005] ...1 78.176688: rtcpu_vinotify_handle_msg: tstamp:2758316633 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2758316213 data:0x00000001
kworker/5:1-114 [005] ...1 78.228683: rtcpu_vinotify_handle_msg: tstamp:2758825889 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2758825312 data:0x044b0002
kworker/5:1-114 [005] ...1 78.228685: rtcpu_vinotify_handle_msg: tstamp:2758825997 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2758825334 data:0x00000000
kworker/5:1-114 [005] ...1 78.228686: rtcpu_vinotify_handle_msg: tstamp:2759351444 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2759351030 data:0x00000000
kworker/5:1-114 [005] ...1 78.228686: rtcpu_vinotify_handle_msg: tstamp:2759358307 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2759357886 data:0x00000001
kworker/5:1-114 [005] ...1 78.228687: rtcpu_vinotify_handle_msg: tstamp:2759867566 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2759866985 data:0x044b0002
kworker/5:1-114 [005] ...1 78.228688: rtcpu_vinotify_handle_msg: tstamp:2759867674 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2759867007 data:0x00000000
kworker/5:1-114 [005] ...1 78.280688: rtos_queue_peek_from_isr_failed: tstamp:2760179308 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 78.280690: rtcpu_vinotify_handle_msg: tstamp:2760393116 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2760392702 data:0x00000000
kworker/5:1-114 [005] ...1 78.280691: rtcpu_vinotify_handle_msg: tstamp:2760399978 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2760399558 data:0x00000001
kworker/5:1-114 [005] ...1 78.280691: rtcpu_vinotify_handle_msg: tstamp:2760909238 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2760908658 data:0x044b0002
kworker/5:1-114 [005] ...1 78.280692: rtcpu_vinotify_handle_msg: tstamp:2760909348 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2760908680 data:0x00000000
kworker/5:1-114 [005] ...1 78.280693: rtcpu_vinotify_handle_msg: tstamp:2761434788 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2761434374 data:0x00000000
kworker/5:1-114 [005] ...1 78.280694: rtcpu_vinotify_handle_msg: tstamp:2761441650 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2761441231 data:0x00000001
kworker/5:1-114 [005] ...1 78.332683: rtcpu_vinotify_handle_msg: tstamp:2761950910 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2761950330 data:0x044b0002
kworker/5:1-114 [005] ...1 78.332684: rtcpu_vinotify_handle_msg: tstamp:2761951017 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2761950352 data:0x00000000
kworker/5:1-114 [005] ...1 78.332685: rtcpu_vinotify_handle_msg: tstamp:2762476458 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2762476047 data:0x00000000
kworker/5:1-114 [005] ...1 78.332686: rtcpu_vinotify_handle_msg: tstamp:2762483321 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2762482904 data:0x00000001
kworker/5:1-114 [005] ...1 78.332687: rtcpu_vinotify_handle_msg: tstamp:2762992584 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2762992003 data:0x044b0002
kworker/5:1-114 [005] ...1 78.332687: rtcpu_vinotify_handle_msg: tstamp:2762992693 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2762992025 data:0x00000000
kworker/5:1-114 [005] ...1 78.384685: rtcpu_vinotify_handle_msg: tstamp:2763518134 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2763517719 data:0x00000000
kworker/5:1-114 [005] ...1 78.384687: rtcpu_vinotify_handle_msg: tstamp:2763524985 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2763524576 data:0x00000001
kworker/5:1-114 [005] ...1 78.384688: rtcpu_vinotify_handle_msg: tstamp:2764034256 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2764033676 data:0x044b0002
kworker/5:1-114 [005] ...1 78.384689: rtcpu_vinotify_handle_msg: tstamp:2764034363 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2764033697 data:0x00000000
kworker/5:1-114 [005] ...1 78.384690: rtcpu_vinotify_handle_msg: tstamp:2764559817 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2764559392 data:0x00000000
kworker/5:1-114 [005] ...1 78.384690: rtcpu_vinotify_handle_msg: tstamp:2764566656 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2764566249 data:0x00000001
kworker/5:1-114 [005] ...1 78.436756: rtcpu_vinotify_handle_msg: tstamp:2765075926 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2765075348 data:0x044b0002
kworker/5:1-114 [005] ...1 78.436765: rtcpu_vinotify_handle_msg: tstamp:2765076035 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2765075369 data:0x00000000
kworker/5:1-114 [005] ...1 78.436772: rtos_queue_peek_from_isr_failed: tstamp:2765179816 queue:0x0b4a3c58
kworker/5:1-114 [005] ...1 78.436775: rtcpu_vinotify_handle_msg: tstamp:2765601489 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2765601064 data:0x00000000
kworker/5:1-114 [005] ...1 78.436778: rtcpu_vinotify_handle_msg: tstamp:2765608329 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2765607921 data:0x00000001
kworker/5:1-114 [005] ...1 78.436780: rtcpu_vinotify_handle_msg: tstamp:2766117659 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2766117021 data:0x044b0002
kworker/5:1-114 [005] ...1 78.436783: rtcpu_vinotify_handle_msg: tstamp:2766117852 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2766117042 data:0x00000000
kworker/5:1-114 [005] ...1 78.488703: rtcpu_vinotify_handle_msg: tstamp:2766643197 tag:ISPBUF_FS channel:0x00 frame:0 vi_tstamp:2766642737 data:0x00000000
kworker/5:1-114 [005] ...1 78.488708: rtcpu_vinotify_handle_msg: tstamp:2766650038 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2766649593 data:0x00000001
kworker/5:1-114 [005] ...1 78.488710: rtcpu_vinotify_handle_msg: tstamp:2767159303 tag:CHANSEL_PXL_EOF channel:0x00 frame:0 vi_tstamp:2767158693 data:0x044b0002
kworker/5:1-114 [005] ...1 78.488711: rtcpu_vinotify_handle_msg: tstamp:2767159447 tag:ISPBUF_FE channel:0x00 frame:0 vi_tstamp:2767158715 data:0x00000000
kworker/5:1-114 [005] ...1 78.488715: rtos_queue_peek_from_isr_failed: tstamp:2767657434 queue:0x0b4a3c58
Anyone has met same issue or may give me some suggestion.
Thanks in advance.
