Hi Jerry Chang,
after applied two patches that you provided (RCE debug and memory corruption fix), the stability of argus seems to be better, but we still can see the following errors occasionally.
argus log shows
SCF: Error InvalidState: Corr Error Received for sensor 5 .. Continuing!
(in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 643)
[ARGUS] camera 5 had error[STATUS_UNAVAILABLE], exit!
[ARGUS] camera 0 frame queue size 1
[ARGUS] camera 1 frame queue size 1
[ARGUS] camera 2 frame queue size 1
[ARGUS] camera 4 frame queue size 1
[ARGUS] camera 5 frame queue size 0
[ARGUS] camera 6 frame queue size 1
[ARGUS] camera 7 frame queue size 1
[RUNNING] Record Time: 0 Progress: 0 channels, 0 messages
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/FusaCaptureViCsiHw.cpp, function startCaptureInternal(), line 866)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function doCSItoMemCapture(), line 536)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function issueCapture(), line 483)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1530)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1359)
SCF: Error ResourceAlreadyInUse: (propagating from src/common/Utils.cpp, function workerThread(), line 114)
SCF: Error ResourceAlreadyInUse: Worker thread CaptureScheduler frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function waitForUnlock(), line 644)
SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 426)
SCF: Error InvalidState: Capture Scheduler not running (in src/services/capture/CaptureServiceDevice.cpp, function addNewItemToSchedule(), line 1004)
SCF: Error InvalidState: (propagating from src/services/capture/CaptureService.cpp, function addRequest(), line 411)
SCF: Error InvalidState: (propagating from src/components/stages/MemoryToISPCaptureStage.cpp, function doHandleRequest(), line 144)
SCF: Error InvalidState: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
SCF: Error InvalidState: Sending critical error event for Session 2
(in src/api/Session.cpp, function sendErrorEvent(), line 1039)
SCF: Error InvalidState: Session has suffered a critical failure (in src/api/Session.cpp, function capture(), line 734)
(Argus) Error InvalidState: (propagating from src/api/ScfCaptureThread.cpp, function run(), line 110)
SCF: Error InvalidState: (propagating from src/components/stages/SensorCaptureStage.cpp, function doHandleRequest(), line 87)
SCF: Error InvalidState: Sending critical error event for Session 4
SCF: Error InvalidState: Sending critical error event for Session 7
SCF: Error InvalidState: Sending critical error event for Session 1
SCF: Error InvalidState: Sending critical error event for Session 6
SCF: Error InvalidState: Sending critical error event for Session 0
[ARGUS] camera 4 had error[STATUS_UNAVAILABLE], exit!
[ARGUS] camera 7 had error[STATUS_UNAVAILABLE], exit!
[ARGUS] camera 6 had error[STATUS_UNAVAILABLE], exit!
[ARGUS] camera 2 had error[STATUS_UNAVAILABLE], exit!
[ARGUS] camera 1 had error[STATUS_UNAVAILABLE], exit!
[ARGUS] camera 0 had error[STATUS_UNAVAILABLE], exit!
dmesg logs show:
Oct 17 19:06:22 kernel: [29326.817761] [RCE] tegra_nvcsi_stream_tpg_disable(vm0, stream=2, vc=3)
Oct 17 19:06:22 kernel: [29326.817766] [RCE] tegra_nvcsi_stream_tpg_disable: channel 3 is already disabled
Oct 17 19:06:22 kernel: [29326.817769] [RCE] tegra_nvcsi_stream_close(vm0, stream=2, csi=2)
Oct 17 19:06:22 kernel: [29326.817771] [RCE] tegra_nvcsi_stream_tpg_disable(vm0, stream=2, vc=2)
Oct 17 19:06:22 kernel: [29326.817773] [RCE] tegra_nvcsi_stream_tpg_disable: channel 2 is already disabled
Oct 17 19:06:22 kernel: [29326.817775] [RCE] tegra_nvcsi_stream_close(vm0, stream=2, csi=2)
Oct 17 19:06:22 kernel: [29326.817777] [RCE] tegra_nvcsi_stream_tpg_disable(vm0, stream=2, vc=1)
Oct 17 19:06:22 kernel: [29326.817779] [RCE] tegra_nvcsi_stream_tpg_disable: channel 1 is already disabled
Oct 17 19:06:22 kernel: [29326.817780] [RCE] tegra_nvcsi_stream_close(vm0, stream=2, csi=2)
Oct 17 19:06:22 kernel: [29326.817782] [RCE] tegra_nvcsi_stream_tpg_disable(vm0, stream=2, vc=0)
Oct 17 19:06:22 kernel: [29326.817784] [RCE] tegra_nvcsi_stream_tpg_disable: channel 0 is already disabled
Oct 17 19:06:22 kernel: [29326.817786] [RCE] tegra_nvcsi_stream_close(vm0, stream=2, csi=2)
Oct 17 19:06:22 kernel: [29326.817788] [RCE] nvcsi_reset_data_lanes: NVCSI_PHY_1_NVCSI_CIL_A_SW_RESET_0 = 00000003
Oct 17 19:06:22 kernel: [29326.817789] [RCE] nvcsi_reset_data_lanes: NVCSI_PHY_1_NVCSI_CIL_B_SW_RESET_0 = 00000003
Oct 17 19:06:22 kernel: [29326.817790] [RCE] nvcsi_reset_lane_merger: NVCSI_PHY_1_LM_SW_RESET_0 = 00000001
Oct 17 19:06:22 kernel: [29326.817791] [RCE] tegra_nvcsi_stream_tpg_disable(vm0, stream=0, vc=2)
Oct 17 19:06:22 kernel: [29326.817792] [RCE] tegra_nvcsi_stream_tpg_disable: channel 2 is already disabled
Oct 17 19:06:22 kernel: [29326.817792] [RCE] tegra_nvcsi_stream_close(vm0, stream=0, csi=0)
Oct 17 19:06:22 kernel: [29326.817793] [RCE] tegra_nvcsi_stream_tpg_disable(vm0, stream=0, vc=1)
Oct 17 19:06:22 kernel: [29326.817794] [RCE] tegra_nvcsi_stream_tpg_disable: channel 1 is already disabled
Oct 17 19:06:22 kernel: [29326.817795] [RCE] tegra_nvcsi_stream_close(vm0, stream=0, csi=0)
Oct 17 19:06:22 kernel: [29326.843344] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_power_off
Oct 17 19:06:22 kernel: [29326.876238] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_power_off
Oct 17 19:06:22 kernel: [29326.879870] [RCE] tegra_nvcsi_stream_tpg_disable(vm0, stream=0, vc=0)
Oct 17 19:06:22 kernel: [29326.879872] [RCE] tegra_nvcsi_stream_tpg_disable: channel 0 is already disabled
Oct 17 19:06:22 kernel: [29326.879873] [RCE] tegra_nvcsi_stream_close(vm0, stream=0, csi=0)
Oct 17 19:06:22 kernel: [29326.879874] [RCE] nvcsi_reset_data_lanes: NVCSI_PHY_0_NVCSI_CIL_A_SW_RESET_0 = 00000003
Oct 17 19:06:22 kernel: [29326.879875] [RCE] nvcsi_reset_data_lanes: NVCSI_PHY_0_NVCSI_CIL_B_SW_RESET_0 = 00000003
Oct 17 19:06:22 kernel: [29326.879882] [RCE] nvcsi_reset_lane_merger: NVCSI_PHY_0_LM_SW_RESET_0 = 00000001
Oct 17 19:06:22 kernel: [29326.908032] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_power_off
Oct 17 19:06:22 kernel: [29326.943897] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_power_off
Oct 17 19:06:22 kernel: [29326.972016] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_power_off
Oct 17 19:06:22 kernel: [29326.989711] cpufreq: cpu8,cur:2020000,set:2201600,set ndiv:172
Oct 17 19:06:22 kernel: [29327.000456] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_power_off
Oct 17 19:06:22 kernel: [29327.033517] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_power_off
Oct 17 19:06:22 kernel: [29327.183045] cpufreq: cpu8,cur:2083000,set:2201600,set ndiv:172
Oct 17 19:06:24 kernel: [29328.857359] cpufreq: cpu4,cur:2353000,set:2201600,set ndiv:172
Oct 17 19:06:28 kernel: [29333.297642] tegra_cam_rtcpu_runtime_suspend
